Results 1 to 15 of 114
Thread: Rebuild!
04-12-2018, 09:03 AM #1
Rebuild!
My little 2.4 went down yest. Not real sure just yet on the cause . Looks like #6 went lean , didn't do a bunch damage tho. Maybe transferred littke aluminum in bottom #6. It's a all chrome motor so I'm guessing prob need a sleeve if hone won t do it?? Anyone have any suggestions to send block to? And also what bout cost sleeving 1 hole and reassembly if I get all parts? If it's to much I do believe strongly I can do rebuild .. I want this done right but still cheap as possible, any info will be helpful. Thanks s&f
04-12-2018, 09:33 AM #25000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Chris Carson has always done right by me. I've Never had a motor rebuilt but I know tons of people have used them with no complaints. He has helped me out many times
Glasstream15 liked this post
04-12-2018, 09:35 AM #3
James Perry is closer to you!
Josh Peterson
tux974, W2F a V-King liked this post
04-12-2018, 10:26 AM #4
With all the problems you been having you best send the COMPLETE powerhead off to someone else to have it gone thru
04-12-2018, 10:59 AM #5
And what kinda problems. Only changed heads and jetting. Had a box go out and killed #6
04-12-2018, 11:03 AM #6
Just had long conversation with James Perry, he gonna put some his magic on it,, I'll keep this thread goin with updates and pics as it goes.
nitro_rat liked this post
04-12-2018, 11:29 AM #7
Has anyone orderd from powerhead express? Wondering bout quality?
04-12-2018, 05:06 PM #8
04-12-2018, 05:06 PM #9
Pics of #6.
04-12-2018, 05:08 PM #10
04-12-2018, 05:14 PM #11
Yep my plans exactly. Thanks for his info as I couldn't find it but had him n mind. Believe we gonna do sum chest mods and not really sure if I wanna do much else. I will be fishing with the motor also so need keep dependability in mind ,
04-12-2018, 05:18 PM #12
I would cut the intake while you’re in there and probably shave the heads a little or find a set of 2.0L heads. That and a little light chest work and you should be good to go. Oh, I would also grab some 4 petal rubber coated reed cages and stuff them with reeds from CCMS or TDR! Actually that might be your best bang for the buck, it’s a bolt on! Chris just came out with some “stuffers” that bolt on between the reed blocks and the intakes, may orice those vs cutting the intake.
Josh Peterson
04-12-2018, 05:22 PM #13
I have set reeds of his I was bout install , so they will go in new motor, I will get me set of the stuffers as the price isn't far off from one to the other, already have set 33cc I'll b using ,, prob should break in stock heads tho ??
04-16-2018, 04:36 PM #14
04-16-2018, 05:18 PM #15
She's a lamp post.
280 Rebuild- how much to do?
By cheapbeater in forum Technical DiscussionReplies: 24Last Post: 11-17-2011, 03:39 PM -
best place for powerhead rebuild/lower rebuild on Long Island?
By play2win in forum Technical DiscussionReplies: 2Last Post: 08-08-2011, 01:49 PM -
Mercury Tech: 3.0L S/Master Rebuild-Who's a good source for a rebuild ?????
By Liberator*21 in forum Technical DiscussionReplies: 4Last Post: 10-06-2010, 06:39 AM -
Mercury Tech: Powerhead on Mercury 125 hp/to rebuild or not to rebuild? Help! Please?
By rickyo in forum Technical DiscussionReplies: 5Last Post: 06-05-2010, 04:08 PM -
to rebuild or new
By R.I.P. in forum General Boating DiscussionReplies: 1Last Post: 01-11-2008, 11:10 AM
