Results 1 to 15 of 17
04-09-2018, 08:22 PM #1Junior Member
- Apr 2015
- Ontario Canada
Mercury 2.4/2.5 V6 parts FS 80's/90's-clearing out good stock used parts
Mercury 2.5-2.4-2L V6 carb and EFI Hi-Po PARTS REDUCED PRICING JAN '19
REDUCED for quick sale-----I'm clearing out all my remaining used MERCURY parts Please PM me with your email info/# and I can send pics
2.5 PARTS
-small top(1.5") crank stator carrier cap w/brg -$80
-sets switch boxes-$150/set (Hi-Po #7778-A2--9.6 Ohm)
-lower unit prop-shaft 1.190" OD brg journal- $75
-9 and 8 tooth starters $100 ea
-good used 2,5 260HP pistons-1 set 6 pistons (side Pin) w/o rods $275 or $50ea
2.4 MERCURY Carb/ EFI and BP parts for sale
-Stator Top Brg crank cap w/brg HP $80ea
-V^ Merc 2L/2.4L crank (oiler) $250
-HD 5250 rods $120 set or 30 ea
-Hi-Po V6 switch boxes $150 set (Hi-Po #7778-A2 - 9.6Ohms)
- 2x 8000 RPM limiters ($50 ea), wiring harness assembles $35
-One set ‘90’s-V6 (200HP) electrics with coils/wiring $175 (Hi-O/P 40 amp) also have 14ohm electrics w/wiring, trigger and stator+40amp +flywheel $350 --complete system $400
-RODS HD set(s) BP EFI/Mod VP #625-5250-$20ea......also 6 shot peened -$40 ea
-1.87 stock '90's Big Brg Lower unit (housing only 200HP) PN 1647-9147 v-good shape $200 little use as gutted gears to install in CLE unit I repaired.
-2.4 Lower Unit 1:87 prop shaft -1.190" OD brg journal-$85
-200 HP stock used pistons w/rods or single port/star-board -Set/w/rods $150 or each w/o rod $25-One new .020” over stock piston w/rings $100
-Complete 200HP 1990 - 1991 stock 1 pc hood (Main + 2 lower underside side bases) $175
-New V6 engine harness engine to dash Key $90
-stock flywheels $75, 8 & 10 tooth starter $75, misc electrical parts-eng wiring
2.0 Ltr 150XS PARTS-
-set head gaskets #27-18785-1 $25/set (150HP)
NOTE-handling/shipping extra-Pricing in USD$
04-09-2018, 08:56 PM #2
pm sent
06-24-2018, 08:42 AM #35000 RPM
- Mar 2016
- Anza, CA
- 229
- 7
What carbs are they and do you have picture of the one piece hood and parts
06-24-2018, 10:05 AM #4Junior Member
- Apr 2015
- Ontario Canada
07-12-2018, 10:03 AM #5Member
- Jul 2018
- hartford WI
- 39
- 7
I'm looking for a one piece exhaust plate or a two piece with solid motor mounts for a 2.4 mercury outboard also need brass bushings all the parts that slide on the shaft that pivots the motor for steering ,sorry about the lack of technical term.
Thanks Floyd
07-13-2018, 06:09 AM #6Junior Member
- Apr 2015
- Ontario Canada
07-14-2018, 08:24 AM #75000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
Is the lower a big bearing ratcheting case
07-15-2018, 04:09 PM #8Junior Member
- Apr 2015
- Ontario Canada
07-16-2018, 08:54 AM #95000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
What's the casting number on top of lower unit
07-16-2018, 08:57 AM #105000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
Lower unit id
I'd for high performance lower and preferred 200 case
07-16-2018, 09:04 AM #115000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
1647-9147 1647-9147C 1647-9147C-1 are all big bearing ratcheting case, C2, C3,C4 are small bearing cases.which aren't linked for hp applications
07-16-2018, 08:01 PM #12Junior Member
- Apr 2015
- Ontario Canada
07-22-2018, 01:59 PM #13Member
- Jul 2018
- hartford WI
- 39
- 7
I found a exhaust adaptor plate on ebay thanks for your repley
07-22-2018, 07:21 PM #14
Pm sent
Life's a garden.....dig it!
08-10-2018, 03:37 PM #15Member
- Dec 2016
- texas
- 44
do you have the stator? Do i understand that it is $80? Let me know. I need it for an 86 2.4. thanks
mercury 280 parts to stock up on
By fstboat1 in forum Technical DiscussionReplies: 0Last Post: 07-25-2016, 07:58 PM -
Mercury Tech: Online Mercury parts with stock info.
By TheRickster in forum Technical DiscussionReplies: 3Last Post: 06-30-2009, 12:07 PM -
Anyone know a good source for discounted new Mercury parts?
By lsidonis@msn.com in forum Technical DiscussionReplies: 37Last Post: 09-27-2001, 08:26 AM
