Results 1 to 15 of 21
    Apr 2002
    Eastover, NC
    Change to Fat Shaft
    Went to the lake today and had the misfortune of breaking the small prop shaft on my Merc 280 Sportmaster and left a freshly DAH worked 29 SRX at the bottom of the lake! Guess I'll have no choice but to go to a fat shaft since small shafts are so rare. Any parts besides the prop shaft need to be changed to go to the fat shaft? Anyone have a 2.5 Sportmaster prop shaft they want to sell? Thanks.
    Dec 2011
    Ottawa
    A 4 hole CLE 1 1/4 late style propshaft is easier to find with small splines. Fatshaft is same dimensions inside the carrier
    Apr 2002
    Eastover, NC
    Quote Originally Posted by Varmint View Post
    Wouldn't happen to know the part number would you? I'm assuming it would work in the sportmaster?
    1 1/4" small shaft has been NLA for years. All you need is the fat shaft, seal kit, retainer lock. Recommend a new retainer nut as well.
  5. Likes WillySteve liked this post
    Apr 2002
    Eastover, NC
    Quote Originally Posted by Dave Strong View Post
    Thanks Dave!
    Apr 2016
    new brunswick
    do you know if I can get a new pres-in hubs for the fat shaft for my 2 chopper props?
    Quote Originally Posted by friendbroker View Post
    Have to be weld in.
  9. #8
    Jan 2003
    aalsmeer
    Apr 2016
    new brunswick
    Have to be weld in.
    thank you
    next question where can I buy a hub ? weld in hub .
    I tried HMShubs they dont have anything for fatshaft .
  11. #10
    Most the custom prop shops have them but not sure they sell them. Some more the hub out slightly larger and do final balance when done.
  12. #11
    Apr 2016
    new brunswick
    thank you for your help I think you just explained to me that I'm going to be buying a new Prop no one around here does custom prop work and the cost of that custom work may exceed the cost of the new prop? thanks again
  13. #12
    Hoss Propellers charges $250. Betting most charge around that.
  14. #13
    Dec 2011
    Ottawa
    Call billy eaves or bblades,some choppers cant be converted to fat shaft,
  15. #14
    May 2008
    KEYSTONE HEIGHTS FL./ Moncks Corner Sc
    Can you use a small prop shaft out of a stock 2.5 fishing motor lower on a sportmaster?
  16. #15
    Quote Originally Posted by MUDSHARK View Post
    No, not unless you use a smallshaft carrier.
  1. Replies: 10
    Last Post: 01-27-2015, 11:53 AM
  2. Mercury Tech: small to fat shaft change
    By dad in forum Technical Discussion
    Last Post: 10-29-2013, 11:08 AM
  3. what tools do i need to change a prop shaft
    By hosejockey4506 in forum Technical Discussion
    Last Post: 07-27-2008, 08:04 PM
  4. Mercury Tech: How to change Optimax 200 25" shaft length to 20"
    By silomon in forum Technical Discussion
    Last Post: 07-20-2008, 01:50 PM
  5. Shaft change
    By baja1000 in forum Technical Discussion
    Last Post: 01-17-2008, 09:09 PM
