Results 1 to 6 of 6
    Mar 2017
    central fl
    300x tps voltage sweep
    When doing a voltage sweep of the tps on a 300x with the engine running is it normal for the engine to revup on it's own?
    Jul 2002
    Copiague LI NY
    the voltage of the TPS is the only way the motor knows where the throttle is at and therefore how much fuel to add or take away...So yes ANY FLUCTUATION IN voltage will cause the engines rpm to increase or decrease....
    1984 28 ghost twin 200 Yamah ProVs (SOLD)
    1997 21 Superboat Legend 250 VMAXXX (SOLD)
    2001 25 Concept CC 250EFI (SOLD)
    2002 24 Superboat Step 250EFI (SOLD)
    1997 21 Checkmate Pulsare 200EFI Merc (Beater Boat)(SOLD)
    1994 20 Hydrasport 225 Optimax (SOLD)
    1998 27 progression Twin 225 Mercs (SOLD)
    2005 23 Kryptonite 300 Promax (SOLD)
    Mar 2017
    central fl
    My rpms gradually increase as I
    Mar 2017
    central fl
    My rpms gradually increase as I increase the voltage but then when I reach a certain point the rpms increase 2k or more?
    Jul 2002
    Copiague LI NY
    Quote Originally Posted by 65gamblerman View Post
    is this in water in gear or just freereving?
    Feb 2014
    Missouri
    If it is a opti the tps will call for more air and fuel through the compressor dfi system befor the throttle plate opens and map sensor speed density starts to control a/f
    why it jumps rpm my be in the performance profile as load normally goes up about 1500-2500 when you start to climb on plane.
    It’s why troll control works on some but not ski tow. The pcm (propulsion control module) can adjust timing. Dfi and fuel injectors to bring rpm up, ski tow takes the electric throttle.
    you will get the same reading with key on engine off. And doing a key off ohms sweep will catch dead spots better. Unless you after a vibration condition.
  1. Who makes a 270 degree sweep gauge?
    By 2.5-21 in forum General Boating Discussion
    Last Post: 09-19-2014, 07:57 AM
  2. Mopar makes cleen sweep!!!
    By T-REX in forum Other Motorsports
    Last Post: 04-03-2006, 09:48 AM
  3. Quartershots sweep Georgetown!
    By us1ss in forum General Boating Discussion
    Last Post: 07-01-2002, 06:13 PM
  4. Quartershots sweep Altamonte Springs
    By makinrain in forum General Boating Discussion
    Last Post: 06-01-2002, 09:00 AM
