Results 1 to 2 of 2
03-31-2018, 08:51 PM #1
Mercury 2.0L V6 Build Questions - Head Work and Sleeve Replacement
Guys, my LA Sleeve came in this week for the repair of hole #6 in my 1996 2.0L fatblock. The sleeve is "almost" identical -
The new sleeve is missing the little slot at the top of the exhaust port. How important is this slot and is it worth cutting it into the sleeve? This is their thickest sleeve at 1/8 - needed because my original was badly damaged when the rod bent.
Inputs appreciated! Gordon
04-01-2018, 07:53 AM #2
Idle relief. I know it affects the cranking compression number. Will probably run ok without it but may cause strange tuning issues? That hole will probably have 5-7 lbs more compression on the gauge without it.
Josh Peterson
By Gordon02 in forum Technical DiscussionReplies: 54Last Post: 01-28-2018, 04:49 PM -
How difficult is it to build a v6 2.5 mercury power head?
By simplyorange in forum Technical DiscussionReplies: 29Last Post: 04-08-2017, 08:27 AM -
Mercury 2.4 build questions, Mystery block.
By Zoomba in forum Technical DiscussionReplies: 44Last Post: 02-04-2014, 01:19 PM -
150hp Mercury head Questions
By bobkyle2 in forum Technical DiscussionReplies: 5Last Post: 03-15-2011, 04:36 PM -
Nikasil sleeve replacement
By Dave@DunnWright in forum Technical DiscussionReplies: 6Last Post: 01-21-2002, 08:15 PM
