Results 1 to 12 of 12
03-30-2018, 08:19 PM #15000 RPM
- Nov 2008
- martinsburg, wv
- 398
1994 johnson 115 hp warped carb bowls.
1994 xflow 115/80 jet has leaking carb bowls - new gaskets, the bowls are slightly warped up in the center. looks like they are no longer available and ill need to find a used set. in the mean time, can i tape sandpaper to glass and sand them smooth to get me through until i locate a set? thanks guys.
03-30-2018, 09:14 PM #2
Yes.
oldschoolnc liked this post
03-30-2018, 09:22 PM #35000 RPM
- Feb 2009
- Dunnellon, Fl. / Cincinnati, Oh
- 419
- 62
- 28
- 136
- 162
Worked for me. 150 gt cross flow. Too cheap to buy new parts!
oldschoolnc, 71V153 liked this post
04-01-2018, 01:19 PM #4
yes just sand them flat, if it dont work just cast some of your own in either Aluminium or a grp composite.
so many people have had the same problem with these poorly made things.
somewhere on YouTube a fella gas made about 4 of them for people in alloy, no more problems once made of alloy.
04-02-2018, 10:41 AM #5
Get some used cheap ass carbs on ebay that have alum bowls and good for life.But be sure the carbs have the mid range jet in the bowls and not in the carb bodies.
04-02-2018, 03:19 PM #6'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
04-02-2018, 03:30 PM #7
Type II on left.
04-02-2018, 05:20 PM #8
Yep sorry your right.
04-02-2018, 05:27 PM #9
Actually the early 70s had the mid range jets in the carb bodies.Anyway all 3 will work,v-4 -v6 bowls.
04-02-2018, 05:29 PM #10
We here call them plastic bowls TUPPERWARE
04-02-2018, 07:10 PM #11'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
04-02-2018, 07:16 PM #12'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
Carb Bowls Needed 0398701
By ufg8torzr1 in forum Parts WantedReplies: 2Last Post: 03-11-2016, 12:37 PM -
OMC Tech: New style plastic float bowls how do I tell if they're warped?
By pcrussell50 in forum Technical DiscussionReplies: 9Last Post: 06-02-2015, 04:28 AM -
OMC Tech: Warped carb bowls
By Captain75 in forum Technical DiscussionReplies: 6Last Post: 09-25-2013, 08:41 AM -
OMC Tech: 1994 Johnson 225 Carb running rich ?
By captglm in forum Technical DiscussionReplies: 4Last Post: 06-25-2010, 09:01 PM
