Results 46 to 60 of 62
Thread: Carlson C500 Project
10-20-2018, 08:41 AM #46"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
10-20-2018, 05:25 PM #47
To pour the transom and knees you just need forms to fill. Like so:
NICE PAIR liked this post
10-20-2018, 08:39 PM #48Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Are there stands, fibers in the mixture?
10-21-2018, 06:17 AM #49"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
10-21-2018, 07:56 AM #50Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Maybe we could use chopper type and blend mix it in if needed?
10-21-2018, 05:05 PM #51Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
The stuff is made from q-cells (light weight resin extender) some milled fibers (strong, but heavy) and cab-o-sil (thickener) from what I have seen of it. There are just so many fillers you can add to resin. You could add chop fibers..Main thing is not to over cataylize the resin and cause too much heat build up. I would suggest several pours, letting each cool off before pouring again.
10-21-2018, 05:54 PM #52Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
All seems doable, not sure about leaving it too long between pours. Curing line might be a problem? Seems like a lot of work instead of ply.
10-22-2018, 05:08 AM #53
I'm not tryin to hi-jack this thread but I always thought that a laminated, builtup transom would be stronger. I am removing ALL the wood from my Checkmate and the transom would be a good canidate for pouring after being gutted. I had be thinkin of using coosa type board in the transom with epoxy and glass cloth. Thanks
Gary"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
10-22-2018, 05:56 AM #54Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
What material are you using for the forms ? Don't think there is a weight advantage?
10-22-2018, 07:20 AM #555000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 192
Olboatman, what are you thinking about pouring, trouble is, your MX-13 will come apart fairly easy, Instigator put a new plywood transom in my MX-14, came out sweet. I have a Carlson Contender and I don't think it will come apart, so I'm thinking of pouring it with seacast or arjay.
10-22-2018, 03:57 PM #56
Poured the transom in my 16R too. 7lbs per gallon cured. Used just under 5 for transom and knees. ArJay compound.
10-22-2018, 04:03 PM #57
Knee forms and transom plug:
10-22-2018, 04:06 PM #58Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Very good, big flares on the Porsche
10-22-2018, 08:42 PM #59
11-13-2018, 08:47 PM #605000 RPM
- Mar 2016
- cincinnati, ohio
- 668
- 145
- 33
- 279
- 192
Been about three weeks, any updates, I know it's cold in Ohio, but you in Florida?????
new boat new project, 70s glastron/carlson 15'
By Steel_drifter in forum Fiberglass and Composites DiscussionReplies: 10Last Post: 05-14-2016, 07:04 AM -
My Carlson C500 Has New Life....Look
By motoxconnection in forum General Boating DiscussionReplies: 13Last Post: 09-24-2006, 07:53 PM -
Prop Selection 115 Merc 81 Carlson C500
By motoxconnection in forum Props, Setup, and RiggingReplies: 2Last Post: 09-19-2006, 10:39 PM -
carlson ct-16
By Erick in forum General Boating DiscussionReplies: 0Last Post: 07-23-2003, 12:42 PM
