Results 1 to 6 of 6
Thread: Mariner 220HP 2.4l XRI 88 model
03-27-2018, 03:11 PM #1Member
- Feb 2018
- SA
- 52
- 9
Gooday gents how can i repair this engine ,the piston ring on no2 broke and got lodged between the cylinder wall and piston, somebody tried to remove it with even more damaging results which caused a crack in the cylinder wall ,on the same piston the rod hit a hole in the casing .thanks guys for your valuable input ,i appreciate
03-27-2018, 07:57 PM #2
Will be cheaper to find a used block.....
03-28-2018, 02:46 PM #3Member
- Feb 2018
- SA
- 52
- 9
Is there another ecm ican use on this engine apart from this 14632A2 any ecm that will give it better performance perhaps easier and cheaper to find ,i have to replace the old one
03-29-2018, 07:34 AM #45000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
That looks like a std. chrome bore motor. a good machine shop should be able to sleeve it, weld crack, & deck block. He,s a long way from you, but I would call chris carson marine. he does that type of work.
03-29-2018, 08:57 AM #5
James Perry also may be able to help.
Josh Peterson
03-29-2018, 11:45 AM #6
I have dealt with both Chris and James and both are top notch, very capable individuals.
RockTeam Junk
1987 220hp mariner??????????????
By blue wonder in forum Technical DiscussionReplies: 3Last Post: 03-27-2018, 04:49 PM -
75 hp mariner model#0a995151 loss of power
By Darianbrown in forum Technical DiscussionReplies: 0Last Post: 07-15-2014, 08:42 PM -
What year model is this Mariner 150 ???
By Javelin409B in forum Technical DiscussionReplies: 1Last Post: 11-12-2008, 07:27 PM -
Mercury / Mariner Model # ?
By inspectorlance in forum Technical DiscussionReplies: 4Last Post: 10-20-2006, 08:21 PM -
Mariner year model
By JLeus in forum Technical DiscussionReplies: 4Last Post: 03-03-2006, 08:40 AM
