Results 1 to 15 of 16
Thread: Water pump impeller
03-26-2018, 07:33 AM #1
Water pump impeller
Is it wise to replace impeller every year after long winter storage. Do you have to replace housing and all gaskets and wear plate also?
1986 cougar mtr 21
2003 supra launch ssv
03-26-2018, 08:21 AM #2
What motor? On 3 liter you dont have to change housing unless damaged. We do cooling service on customers boats every 3 years. On my own boat I change impeller every year. JMO
03-26-2018, 10:24 AM #3
260 efi offshore. Guess it’s best to take a look at housing and change impeller since it’s been same position for 8 months
1986 cougar mtr 21
03-26-2018, 04:29 PM #4
change it all including the seal plate below the pump every season...cheap insurance agaist overheating or losing an impeller blade...
1984 28 ghost twin 200 Yamah ProVs (SOLD)
1997 21 Superboat Legend 250 VMAXXX (SOLD)
2001 25 Concept CC 250EFI (SOLD)
2002 24 Superboat Step 250EFI (SOLD)
1997 21 Checkmate Pulsare 200EFI Merc (Beater Boat)(SOLD)
1994 20 Hydrasport 225 Optimax (SOLD)
1998 27 progression Twin 225 Mercs (SOLD)
2005 23 Kryptonite 300 Promax (SOLD)
03-26-2018, 04:35 PM #5
My boat is not stored in a climate controlled area so I pull my lower every fall before the first freeze. Since I have it off I usually pressure test, change the oil, and replace the impeller. This year I think I’ll change the whole pump since I know it’s been 3 or 4 years since the last time event though it still looks good!
Josh Peterson
03-26-2018, 05:53 PM #6
Cheap issuran e is right. Better safe than sorry. Thanks all
1986 cougar mtr 21
03-27-2018, 09:10 PM #7
89984 imellers every year, floppy 43026 impellers 3-5 years.
Fishinmymission thanked for this post
03-28-2018, 08:46 AM #85000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
Are those two impellers interchangable on the standard 2.5 lower units? I see the 89984 listed as the part for the standard lower unit.
Any idea what increases the service life of the 43026 impeller?
Edit comparing the pictures looks like the impellers are not interchangeable. Looks like the 43026 is for the 3 liter models and reportedly lasts much longer.
After getting impeller pieces jammed in my 2.5 once It's back to changing the 89984 impeller every season.Last edited by Fishinmymission; 03-28-2018 at 08:54 AM.
03-28-2018, 08:52 AM #9
The 47-89984T has the brass sleeve that’s stronger and holds up under high RPM’s ! I wouldn’t trust any other . It is what it came with from the factory .
04-22-2018, 03:50 PM #10
So where is the best place to shop for the better ones?. Merc dealer?.
04-22-2018, 04:15 PM #11
Yes ! Have your local merc dealer order a 47-89984T !
04-22-2018, 05:06 PM #125000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
The most common failure on most is that the impeller will become 'set' after sitting.
04-22-2018, 05:06 PM #13
Not much of a merc dealer if they have to order an 84 impeller.
pkstv liked this post
04-22-2018, 06:33 PM #14
So the merc parts list , lists a #43026t2, for my 1999 250 efi's. but I should use a 47-89984t ?..
04-22-2018, 07:24 PM #15
Water pump impeller mod
By merc_racer in forum Technical DiscussionReplies: 49Last Post: 02-28-2013, 11:49 PM -
water pump impeller
By greg88 in forum Technical DiscussionReplies: 1Last Post: 06-22-2008, 03:20 PM -
water pump impeller
By ebuck in forum Technical DiscussionReplies: 6Last Post: 04-23-2006, 06:37 PM -
Water pump impeller question
By Fish in forum Technical DiscussionReplies: 10Last Post: 04-10-2005, 10:41 AM
