Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
    Jun 2012
    Stator differances
    I have a bridgeport i built and broke in last year and have a issue with the motor not reving past 7k rpm and im wondering if it is the stator. Could someone please tell me the difference between the 16 amp racing stator vs the standard 16 amp.
    Sarasota, FL
    As far as I know there are 16 amp stators and 40 amp stators. I didnt know there was a standard 16 amp and a high perf 16 amp stator. I do know that if you've had a stator go bad and replaced it with new that it usually will break down the switch boxes and that they will soon be bad also and that anytime you change the stator you should replace the switch boxes as well. Ive also had rectifier issues that would keep the rpm down. Are your gauges doing anything weird when running up in the rpm like jumping around etc? Is your 16 amp stator red? Also is your BP efi or carb?
    Usually when you stator goes it wont get up on plain but will idle and run fine on the hose or in the water in nuetral.
    Heres a link to a good read with a lot of great info on stators
    http://www.outboardstators.com/diagnostics.html
    Rob Lankford
    1988 20' Action Marine 2.4 200
    Previous owned boats worth mentioning
    1976 17' Action Marine 2.4 200
    1984 20' Action Marine 2.5 200
    1983 17' Hydrostream V-King 2.4 Bridgeport
    2003 LPB STV RR COPY 2.5 280 /300 Drag
    2005 LPB STV RR COPY 2.5 280
    2005 Baja 23 Outlaw 6.2 Mercruiser
    2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
    2009 FTP Quarter Shot T3 Race 2.5 280
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by Hot Shot Merc View Post
    And don’t forget the old 9 amp stator...
    Josh Peterson
    Jun 2012
    Stator is black and im using a green flexplate flywheel. Gauges are acting normal. This is a carbed Bridgeport with a 5 pedal front. Compression was at 132-135 last year before i put it up for the winter. Prop pitch didnt make a differance either. Went from a 26 to a 24
    Sarasota, FL
    Yep but figured it didnt matter LOL
    Rob Lankford
    Jun 2012
    It was worth a try
    Mar 2015
    DFW
    What models had the 9amp systems on them?
    Sarasota, FL
    Maybe a coil? A bad coil will hold rpm back
    Rob Lankford
    Sarasota, FL
    Quote Originally Posted by Noah Burns View Post
    Older smaller hp 3 and 4 cyl motors used them
    Rob Lankford
    Jul 2012
    Lufkin, Texas
    The V6 was 9 amp from introduction to sometime in the early 80’s. 81-82ish. Can use the 9 amp stuff with 16 amp flywheel, usually just ditch the regulator. You can run the 16 amp stator with 9 amp flywheel, add regulator.
    Josh Peterson
    Jun 2012
    I bought this ignition used off of a running motor. Is it even possible to put a 9 amp stator under a 16 amp flywheel?
  12. #12
    TN
    a racer told me the fishing motor switchboxes wouldn't turn as many rpms.
  13. #13
    Jun 2012
    Sorry about that nitro you got your responce in before i posted my question. When i bought the ignition i didnt ask if it was off a fishing motor or off another bridgeport. Fail on my part.
  14. #14
    Sarasota, FL
    Quote Originally Posted by mercrazy View Post
    Yep, the 300 drags and 260's run a diff switch box
    Rob Lankford
  15. #15
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by 89Talon18 View Post
    No worries! You can definitely put a 9 amp stator under a 16 amp flywheel and it will work too, but the 16 amp regulator will need to be removed.
    Not sure what issues might arise if the regulator was left in place...
    Josh Peterson
  1. 2.5 differances
    By zx14 in forum Technical Discussion
    Last Post: 10-19-2015, 03:23 PM
  2. Mercury Tech: ECU differances are
    By TEXAS20225 in forum Technical Discussion
    Last Post: 08-23-2009, 03:15 PM
  3. OMC Tech: OMC V8 what are the differances?
    By 76Stingray in forum Technical Discussion
    Last Post: 10-01-2008, 07:48 AM
  4. Prop Differances
    By BIRDZY in forum General Boating Discussion
    Last Post: 09-01-2005, 11:31 AM
  5. Differances between ECU's
    By Rocket in forum Technical Discussion
    Last Post: 04-01-2002, 01:18 AM
