Results 16 to 30 of 33
    Jun 2012
    Where can i get a list of part pn# for the correct ignition or be pointed in the direction tp look
  2. #17
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by mercrazy View Post
    a racer told me the fishing motor switchboxes wouldn't turn as many rpms.
    As far as I know all the swtch boxes are the same. There isno rev limiter built in to the switch box. 90 hp 3 cylinder, 150 2.0, 2.5 260, same switch box...
    I don’t know nuttin’ bout no 300 drag though! Never seen one!
    Josh Peterson
  3. #18
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by 89Talon18 View Post
    CDI’s website is helpful to look stuff up and compare part #’s. They also have a big PDF troubleshooting manual that’s worth twice the price (free!).
    Mallory switch boxes used to be the best, they sold out to Sierra a few years back. The Sierra should be the same. The only parts I’d be wary of is the blue CDI “race” stuff. It must be used as a set and id “digital” which as far as I can tell just means it may or may not get along with your particular flywheel magnets!
    Josh Peterson
  4. #19
    Jun 2012
    I using wh-22 carbs with the slosh tubes and baffles which i believe were on the old oval port mod-vp motors. Ive got .086 mains in it know but would like to know what the factory idles where
  5. #20
    Jul 2012
    Lufkin, Texas
    Stator is black and im using a green flexplate flywheel.
    I missed that...
    The green flexplate flywheel should be 9 amp. It works with the 16 amp stator too though. If your electrics came from the same motor as the flywheel you have a 9 amp system. There was also a red flexplate flywheel that was 9 amp IIRC...
    Josh Peterson
  6. #21
    Jul 2012
    Lufkin, Texas
    Probably .046. That’s what the jet charts say for bridgeport (wh-46) and also wh-22 (2.4 200).
    Josh Peterson
  7. #22
    Jun 2012
    At this point im thinning its was a pieced together igniton that was on a running motor but not original to the motor it was on
  8. #23
    Jul 2012
    Lufkin, Texas
    Mother Merc was known to throw stuff together using what parts they had on hand. Anything is possible now that time and PO’s have gone by!
    Josh Peterson
  9. #24
    Mar 2010
    houston, tx
    I missed that...
    The 16 amps came green also, I have a couple.
  10. #25
    Sarasota, FL
    Found this on another thread "Not a rev limiter built in. Theres differences in the ohms. The output between stock and high perf is different. The high pref switchboxes have better electronics ( transistors etc.) in them. This will allow a motor to spin at higher RPMs before the spark signal to the coils "brakes down" as compared to the "standard" switchboxes. Stock box will read 14,000 ohms. HighPerf box will read 9,000 ohms."
    Pro Marine sells a Mercury racing High Perf switch box and another that fits 135-200 hp
    Rob Lankford
    1988 20' Action Marine 2.4 200
    Previous owned boats worth mentioning
    1976 17' Action Marine 2.4 200
    1984 20' Action Marine 2.5 200
    1983 17' Hydrostream V-King 2.4 Bridgeport
    2003 LPB STV RR COPY 2.5 280 /300 Drag
    2005 LPB STV RR COPY 2.5 280
    2005 Baja 23 Outlaw 6.2 Mercruiser
    2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
    2009 FTP Quarter Shot T3 Race 2.5 280
  11. #26
    TX......somewhere?
    jus gonna throw this out there.. I've turned a35's/a66's, no regulator, green fw with a12's/a14's ta 9 grand on several motors without any problems.... saved $$$.. .. now a 10 grand + motor might be a different story..
    only built a coupla those but did use tha high dollar junk on 'em jus in case...
  12. #27
    TN
    maybe you're running out of horsepower.
    boat weight, timing, engine height, etc.
  13. #28
    TX......somewhere?
    http://www.marineengine.com/parts/me...utboard-parts/
  14. Likes Noah Burns, Ace liked this post
  15. #29
    Jun 2012
    Hull weight im not sure on, brochure from the manufacturer says 750. My timing is set to 25 deg wot at cranking speed. CL of prop shaft is 1.25" above. 26p pulls to 7000 rpm and stays. 24p just pulls to 7000 quicker then peters out. Running out of hp is going to be a disappointment
  16. #30
    TX......somewhere?
    22 factory are.. mains, 1,3,4,6= 074's, 2,5=076's (think most charts show wh 46's on carb BP.. 22's were mostly oval port motors)
    idle, all 44's/46's I think?...........
    jan.... if ya start changin' mains, pay attention no mater what merc actually calls for..........
    25*?.. indexed flywheel or jus number one?
  1. 2.5 differances
    By zx14 in forum Technical Discussion
    Last Post: 10-19-2015, 03:23 PM
  2. Mercury Tech: ECU differances are
    By TEXAS20225 in forum Technical Discussion
    Last Post: 08-23-2009, 03:15 PM
  3. OMC Tech: OMC V8 what are the differances?
    By 76Stingray in forum Technical Discussion
    Last Post: 10-01-2008, 07:48 AM
  4. Prop Differances
    By BIRDZY in forum General Boating Discussion
    Last Post: 09-01-2005, 11:31 AM
  5. Differances between ECU's
    By Rocket in forum Technical Discussion
    Last Post: 04-01-2002, 01:18 AM
