Results 1 to 15 of 33
Thread: Stator differances
03-22-2018, 03:01 PM #1
Stator differances
I have a bridgeport i built and broke in last year and have a issue with the motor not reving past 7k rpm and im wondering if it is the stator. Could someone please tell me the difference between the 16 amp racing stator vs the standard 16 amp.
03-22-2018, 04:04 PM #2
As far as I know there are 16 amp stators and 40 amp stators. I didnt know there was a standard 16 amp and a high perf 16 amp stator. I do know that if you've had a stator go bad and replaced it with new that it usually will break down the switch boxes and that they will soon be bad also and that anytime you change the stator you should replace the switch boxes as well. Ive also had rectifier issues that would keep the rpm down. Are your gauges doing anything weird when running up in the rpm like jumping around etc? Is your 16 amp stator red? Also is your BP efi or carb?
Usually when you stator goes it wont get up on plain but will idle and run fine on the hose or in the water in nuetral.
Heres a link to a good read with a lot of great info on stators
http://www.outboardstators.com/diagnostics.htmlRob Lankford
1988 20' Action Marine 2.4 200
Previous owned boats worth mentioning
1976 17' Action Marine 2.4 200
1984 20' Action Marine 2.5 200
1983 17' Hydrostream V-King 2.4 Bridgeport
2003 LPB STV RR COPY 2.5 280 /300 Drag
2005 LPB STV RR COPY 2.5 280
2005 Baja 23 Outlaw 6.2 Mercruiser
2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
2009 FTP Quarter Shot T3 Race 2.5 280
03-22-2018, 04:12 PM #3
03-22-2018, 04:20 PM #4
Stator is black and im using a green flexplate flywheel. Gauges are acting normal. This is a carbed Bridgeport with a 5 pedal front. Compression was at 132-135 last year before i put it up for the winter. Prop pitch didnt make a differance either. Went from a 26 to a 24
03-22-2018, 04:20 PM #5Rob Lankford
03-22-2018, 04:24 PM #6
It was worth a try
03-22-2018, 05:18 PM #75000 RPM
- Mar 2015
- DFW
- 665
- 16
- 42
- 366
- 232
What models had the 9amp systems on them?
03-22-2018, 05:22 PM #8
Maybe a coil? A bad coil will hold rpm back
Rob Lankford
03-22-2018, 05:27 PM #9Rob Lankford
03-22-2018, 05:39 PM #10
03-22-2018, 05:41 PM #11
I bought this ignition used off of a running motor. Is it even possible to put a 9 amp stator under a 16 amp flywheel?
03-22-2018, 05:56 PM #125000 RPM
- TN
- 470
- 7
a racer told me the fishing motor switchboxes wouldn't turn as many rpms.
03-22-2018, 06:08 PM #13
Sorry about that nitro you got your responce in before i posted my question. When i bought the ignition i didnt ask if it was off a fishing motor or off another bridgeport. Fail on my part.
03-22-2018, 06:42 PM #14Rob Lankford
03-22-2018, 06:48 PM #15
2.5 differances
By zx14 in forum Technical DiscussionReplies: 2Last Post: 10-19-2015, 03:23 PM -
Mercury Tech: ECU differances are
By TEXAS20225 in forum Technical DiscussionReplies: 0Last Post: 08-23-2009, 03:15 PM -
OMC Tech: OMC V8 what are the differances?
By 76Stingray in forum Technical DiscussionReplies: 76Last Post: 10-01-2008, 07:48 AM -
Prop Differances
By BIRDZY in forum General Boating DiscussionReplies: 3Last Post: 09-01-2005, 11:31 AM -
Differances between ECU's
By Rocket in forum Technical DiscussionReplies: 1Last Post: 04-01-2002, 01:18 AM
