Results 1 to 4 of 4
    Mar 2005
    tulsa, ok
    Looking for some head.....
    Info.. I need a set of stock heads for a '91 merc xr4 'fat block' part number 187893. Or, if you know what cc these heads are, that would be great. Thanks
    '94 Bullet 20XD W/225 Merc ProMax
    Florida Keys
    Fat block will let you use any 2.5 head....I’d imagine somewhere in the 34-37cc range with that 3.375” bore would put you where you want to be. Should be able to use 2.5 head gaskets too....so you can fine tune your compression if you’re close with thin/thick gaskets.
    '95 STV "The Blue Goose"
    Mar 2005
    tulsa, ok
    That good info, thanks. We're looking for about 125-130 lbs compression. From I've gathered so far, we were thinking a 32cc 2.5 head should put us close. I'd rather it be 130-135 than be below 120.
    Sep 2017
    Ashland city tn
    What is your compression now ? My 2.4 200 went from 120ish to 135ish with 33cc heads
  1. head gasket and cylinder head
    By drtyTshrt in forum Technical Discussion
    Last Post: 03-26-2017, 08:47 PM
  2. EARLY opti head, Low Compression head, Pro XS head on 3.0L
    By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-20-2016, 11:26 PM
  3. Head torque on 4cyl mercruiser 488 the one with the ford BB head
    By baddjonny in forum Technical Discussion
    Last Post: 07-15-2011, 11:02 AM
  4. OMC Tech: 2.7 head repair?? filling head gouges
    By rebible in forum Technical Discussion
    Last Post: 07-13-2008, 09:44 PM
  5. Replies: 5
    Last Post: 08-05-2007, 03:36 PM
