Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 59 of 59
  1. #46
    Sorry, don't do glass/paint work any more. Retired from it after 30+ yrs. There are couple of guys on here in your area that may be able to steer you to a good place to do it if you decide not to tackle it. Congrats on the baby coming in July....
    Mar 2009
    Saint Lucie Florida
    Gotcha, And thank you!
  3. #48
    Mar 2009
    Saint Lucie Florida
    Have a question about Expanding foam, for example if filled the voids under the floor with expanding foam and made two small boxes in the back corners of the boat would this provide more boyancy? if I go with a slightly heavier 4 stoke like the formula race 60 will the boat sit higher up in the water? does it work that way?
  4. #49
    May 2016
    keys
    No. Foam only helps float a boat that's sunk or sinking by displacing water inside the hull. A intact boat is already displacing that water on the outside of the hull. The foam only adds weight.
  5. Likes XstreamVking liked this post
  6. #50
    Mar 2009
    Saint Lucie Florida
    Quote Originally Posted by Whaaaaat View Post
    Makes perfect sense, are most people running no foam at all?
  7. #51
    Empty air chambers to prevent complete sinking are the best way to do it. Complete under floor area sealed with removable plugs is one way. Boxes made from thin glass with a drain hole that can be plugged to seal it watertight. (transom corners.) All opened to allow air circulation when boat is off the water. Styrofoam blocks under deck glued in place with epoxy adhesive is another. Do not use foam below the floors, it will absorb water.
    Apr 2018
    Alaska
ID:	406088In Alaska, we race these boats with 50hp 2-strokes, but they recently changed the rules to allow for 60hp 4-strokes. We achieve a top speed of 74 with a crew of three as pictured, 30 gallons of fuel, and required equipment. The main race is called the Yukon 800. Fairbanks to Galena the first day which is 400 miles, then return to Fairbanks the next day at 6am. A lot of captains are wondering how the Formularace would do on these types of boats and if they would be competitive. A documentary called Legends of the Yukon is available for purchase or rent-streaming at www.akraceproductions.com
  9. Likes Capt.Insane-o, powerabout, Markus liked this post
  10. #53
    7 Post(s)
    If it's anything like all the other 4 strokes, you will be able to lighten load by not having to carry as much fuel.
  11. #54
    FLA
    I have a new Merc Formula 60 4 stroke 4cyl with smartcraft 15 inch 5500.00
    24 Twister
  12. #55
    Mar 2009
    Saint Lucie Florida
    Quote Originally Posted by Z06man View Post
    I would like to buy it, if you still have it in august I will get it from you.
  13. #56
    FLA
    It will be gone
    24 Twister
  14. #57
    Gothenburg, Sweden
    I'd be building a 3cyl yamaha.
    Or a 2 cylinder 70 hp Tohatsu. Light and strong...
  15. #58
    8 Post(s)
    2 cyl 70?
    EDIT >yes I looked it up, 86 the 2 cyl was 70hp, wow!
  16. #59
    FLA
    Last 1
ID:	407281Click image for larger version.
    24 Twister
  1. 2015 mercury 60 hp efi formula race 15 inch shaft tiller handle
    By Matt chickos in forum Outboard Engines
    Last Post: 10-20-2017, 10:30 PM
  2. 60 mercury formula one race
    By mercury2.5 in forum Outboard Engines
    Last Post: 07-28-2014, 07:27 PM
  3. Forget the Formula Race Merc ... the Selva is the real F4 race motor
    By Mark75H in forum General Boating Discussion
    Last Post: 08-14-2011, 09:47 AM
