Results 1 to 15 of 16
    Clear bleed lines?
    Where can you buy in bulk the clear cylinder bleed lines? Part # McMaster Carr or? Thanks
    Jul 2012
    Lufkin, Texas
    Look for “Tygon” fuel line. Locally your small engine shop should have a roll in whatever size you need (bleeds are usually 1/4” IIRC). Just carry a piece and match it up. Anywhere that services mowers, chain saws, weed whackers, etc.
    Or:
    https://www.ebay.com/p/Tygon-Clear-Y...24.m4096.l9055
    Josh Peterson
  3. Likes specboatops liked this post
    GA
    Heat seems to loosen them up make sure you use constant pressure clamps. I made clamps just by wrapping SS spring wire around an appropriate sized screwdriver.
    Jul 2012
    Lufkin, Texas
    Tiny cable ties work too
    Josh Peterson
    Mar 2010
    houston, tx
    Ace hardwares stores normally have it on spools , cut off the amount you need.
    Apr 2011
    Long Beach
    Tygon line... 5552K23
    And proper zip ties...these are cool...the business end is different than normal and designed to be used as hose clamps.
    6705K35
    McMaster part numbers...
  8. Thanks David - WI, V pads thanked for this post
    Quote Originally Posted by lbhsbz View Post
    6705K35
    Some photos of them here: https://www.fuelhoseziptie.com/
    Sep 2015
    Twin Cities, Minnesota
    Are you sure? I thought the bleed lines use 3/32" I.D. which is one size smaller than 1/8" I.D.
  11. Likes 90 5.0 liked this post
    Jul 2012
    Lufkin, Texas
    I’m not sure. I always carry a piece with me and match it up...
    Josh Peterson
    US plastics sells what youre looking for. https://www.usplastic.com/catalog/de...kid=topnavmenu
  14. #11
    Mar 2010
    houston, tx
    Quote Originally Posted by Krazymaan View Post
    Yes the 1/8th are a little loose but ok with good clamps, I get the 3/32” I’m 99.835% sure
    Yantis, TX
    You shouldn't need zip ties on bleed lines. Factory doesn't use them, or any clamp at all. Use the right size line.
    "We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing."
  16. Likes 90 5.0 liked this post
    May 2014
    Livingston, Louisiana
    If you use tygon, use some type of clamp/ tie. If not, good chance it will blow off. The tygon is much softer than the stock hose and doesn't grip the same when hot as the factory hose.
  18. #14
    Apr 2011
    Long Beach
    you absolutely need clamps or ties of some type with Tygon...I've had several fall off without.
  19. #15
    Sep 2015
    Up here in the frozen Midwest. Tygon is good for about 2yrs and then it starts to harden. After my tygon spools are gone I am definitely going back to black hose. At least that can last 20 plus years up here.
  20. Likes David - WI liked this post
  1. Bleed off lines and Enrichment lines
    By Krazymaan in forum Technical Discussion
    Last Post: 02-28-2017, 08:57 PM
  2. 2.5 260 bleed lines
    By Storm94 in forum Technical Discussion
    Last Post: 04-23-2016, 08:21 PM
  3. Best tubing for bleed lines/small fuel lines 2.4 MERC
    By rujr in forum Technical Discussion
    Last Post: 07-10-2013, 10:26 AM
  4. Mercury Tech: Bleed Lines and Why ???????
    By Liberator*21 in forum Technical Discussion
    Last Post: 04-09-2010, 03:10 PM
  5. Colored bleed lines and water dump lines
    By DaveR in forum General Boating Discussion
    Last Post: 02-20-2003, 08:52 PM
