Results 1 to 14 of 14
Thread: Mercury id ?
    Feb 2018
    SA
    Mercury id ?
    Can anybody pls help id on this engine ,this photos is all i have new owner bought it on a auction ,have not seen it dont know anything about it, is this a bridge port or a race engine will it make a reliable fast fishing motor, he tells me it is a 2.5l block 200hp?
    thanks guys i appreciate any help
    TX......somewhere?
    looks ta be "production" motor.. '91 if carbs are correct... outside chance '92... could be 2.0 135/150, 2.4 150 (fat block xr4), 2.5 150 (xr6) 2.5 200.. close as I can tell with what ya got ta work with......
    Feb 2018
    SA
    well thanks sorry cannot be more specific what about the cowl dont it gives you any indication ,that cowl with the openings on the sides was that not for your top range models or racing motors
    Jun 2012
    Indiana
    Thats a fishing motor with a bridgeport cowl. Look at the "custom" bracket on the bottom carb holding the front of the pan. Just like tlwjkw said.
    Feb 2018
    SA
    Ok here is another photo ,the leg is without bottom cowl ,only with a pan and it fasten with bungee cords ,from what i can recall it is only your high perfomance motors that has this
    Sep 2017
    Ashland city tn
    They put bridgeport cowl on a fishing motor
    Sep 2017
    Ashland city tn
    They put bridgeport cowl on a fishing motor. The pan is part of the swap/cowl
    Feb 2018
    SA
    ok thanks guys ,ill see if i can get some more info
    TX......somewhere?
    look for a serial number on tha welsh plug (1st picture).. look for build date stamped on tha "block half" (second picture) kinda behind tha bend in tha timin' arm or on tha block flange............
    Feb 2018
    SA
    thanks ill look for
    80's mid & gearcase. No zinc on gearcase like 80's gearcases. (??) As said, need the serial number off clamp and/or powerhead.
  12. #12
    ...whats that sticker say, on the side of the clamp bracket...
  13. #13
    TX......somewhere?
    anode's showed up early ninties,, maybe '93/94.. when tha cle went away and sporty showed up.....
  14. #14
    Feb 2018
    SA
    thanks guys for your valued opinion ,im going to have look and will have serno tommorow
  1. Article: Mercury Racing Blog: Mercury Sweeps Rouen!
    By Scream And Fly in forum vBCms Comments
    Last Post: 06-06-2012, 01:47 AM
  2. Replies: 8
    Last Post: 03-16-2012, 05:43 PM
  3. Article: Mercury Racing Blog: Team Mercury – Part 3: Earl Bentz
    Last Post: 02-04-2012, 07:55 AM
  4. Replies: 0
    Last Post: 01-15-2012, 07:30 AM
