Results 1 to 8 of 8
    Feb 2018
    Key West
    Looking for Omc thrust washer and nut
    ISO thrust washer and nut to put an SRX prop on a CLE Lower
    Nov 2014
    atlanta
    I HAVE A LOAD OF THRUST WASHERS, IF YOU CAN GIVE ME MEASURMENTS ON WHAT YOU NEED I CAN CHECK THRU THE ONES I HAVE. i would use a caliper if you have one. thanx,mike
    please respond back to me thru pm's
    SOME PEOPLE ARE LIKE SLINKYS, KINDA BORING BUT STILL FUN TO WATCH IF YOU PUSH THEM DOWN THE STAIRS
  3. Thanks 1actionkw thanked for this post
    Nov 2003
    Portsmouth VA
    I have them but you need to fly me down there to hand deliver them��
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
    May 2014
    Livingston, Louisiana
    Call DAH at (262)534-4440. They got what ya need.
  6. Thanks 1actionkw thanked for this post
    Feb 2018
    Key West
    Quote Originally Posted by 99fxst99 View Post
    I can do free room and boat launch anytime you come to the Keys
    Feb 2018
    Key West
    John is out sick for a while , I found the thrust washer. Just need info where I can get the washer behind the nut and the thin nut for the shaft. Thanks for the reply’s
    Jul 2012
    Lufkin, Texas
    I just use a grade 8 flat washer. You can make the nut if you have to but a good boat shop should have one. It’s common for fishing and pleasure boaters to use an OMC prop on a Merc. It’s standard stuff for that...
    Edit:
    https://m.grainger.com/mobile/produc...180321215241:s
    No promises, but something like this should work for the nut...
    Josh Peterson
  10. Thanks 1actionkw thanked for this post
    Nov 2003
    Portsmouth VA
    Quote Originally Posted by 1actionkw View Post
    That's awesome.
  1. Thrust washer
    By delawarerick in forum Parts Wanted
    Last Post: 02-07-2014, 07:40 AM
  2. Need help with a Thrust Washer
    By jayfaro in forum Technical Discussion
    Last Post: 02-05-2011, 11:18 PM
  3. Thrust Washer
    By Richard in forum Technical Discussion
    Last Post: 06-19-2007, 04:30 PM
  4. Thrust Washer
    By Xallison in forum Technical Discussion
    Last Post: 06-25-2004, 10:54 PM
  5. SRX thrust washer
    By Riverratt in forum Technical Discussion
    Last Post: 07-24-2003, 08:14 PM
