Results 1 to 15 of 17
    Black Creek WI
    Preping old flake finish for paint
    Hey all, have some questions for you boat finish guru's. I'm redoing a V-king, the same old same old core, floor and transom. Repairs that I have done many times with great results, if I do say so myself. All my other hydro-stream rebuild had good enough finishes and colors that I left as was or had a body shop burry the flake in clear because of the factory gel coat being gone.
    Well my new project V-king has the same gel coat gone to the point that you can feel the flake when you rub your hand over it. If I liked the colors I would do what I done in the past, have my body shop buddy burry the flake in clear again and be done with it. But this boat has the worse flake color combo that I have ever seen on a Hydro-Stream, even if it was shiny again I would have to put bag over me head to run it, its that ugly! It has a piss colored goldish silver main with bright red high lights down the sides, across the back and under the windshield into the dash, just god awful to look at on a good day.
    With all that said, I want to paint the boat in a color that don't cause me to loose my cookies ever time I look at it. Thinking a nice blue. So what I would like to know is what I have to do to the old flake finish or whats left of it to ready it for a good paint finish, I know that the prep work is 99% of the paint jobs out come, and I want a paint job that I can be proud off that is durable and makes the boat look like it was done right. What do I have to do to the old fake? What primer do I need to use? What is a good paint to use for a novice at best painter? I do have hvlp paint guns. Any and all tips and help is greatly appreciated THANK YOU ALL
    1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
    Argentine township, Mi.
    Hey Wogi, How you been doin man? Damn that color does sound really awful. What year is that critter?
    DaveW
    Dec 2017
    lower al
    we want to throw up to lets see a pic lol. it depends on how bad they are but usually 320 grit on a da sander will knock em down enough for a good 2k primer to hide them then of course sand your primer and so on...
    Black Creek WI
    Quote Originally Posted by crazy horse View Post
    Hey there buddy how have you been, get a chance to wreck that super speed master that you stole from me LOL. The boat is a 79
    Black Creek WI
    Quote Originally Posted by 1980 ENCHANTER View Post
    Hey thanks for the info, I'll try to sneak up on the ugly thing with a camera and take some picks and post tomorrow, but beware I can't be held responsible for loss of work do to a upset stomach
    Dec 2017
    lower al
    my checkmate had the same problem the gel was gone and you could feel the flake pretty bad.After sanding the boat. I used 1 coat of epoxy primer first (not sure it was necessary but did it as precaution) that stuff is like sanding concrete lol. Then 2 coats of regular high build primmer. its basically like you were talking about burying the flakes with the clear but instead its with primer. I use matrix paint products but that's just my preference.
    May 2001
    Charlotte, NC
    Wogi, I'm doing a similar project. The clear on the deck was sun burnt off and it was rougher than hell with the old flake. Took a lot of DAing to get it smooth enough for gel coat for the new metal flake base.
    Good luck-
    Attached Thumbnails Attached Thumbnails IMG_0254.JPG   IMG_0252.JPG   IMG_0253.JPG
    Black Creek WI
    Well after tossing my cookies, I snuck up on it and got theses, VEIWER DISCRECTION IS ADVISED
    Attached Thumbnails Attached Thumbnails 101_0695.jpg   101_0696.jpg   101_0697.jpg   101_0698.jpg   101_0699.jpg
    Black Creek WI
    Well, i'm feeling ill going to lay down now
    Wow, That old girl sure is dog ugly? Ya know Brian I thought I would have busted that SSM by now but it's still turns over real smooth. I haven't kept track of the total hours on the case. I have always pumped fresh lube every two hour or there about. I think the homemade vent kit has help, I've never have had water in the case. I don't run it in rough water. When it does let go I hope I don't loose one of my props or bust the main drive shaft. I hope your doing well, Take care and cover that thing up.
    DaveW
    Jul 2012
    Lufkin, Texas
    That’s a “silverstreak.” It looks like maybe somebody cleared it with some cheap auto paint that yellowed? It should be bright silver and bright red. Looks nice when it’s not covered in a coat of amber...
    Josh Peterson
  12. #12
    Black Creek WI
    I had Steckbaure go threw that case before you beat me up and stole it LOL, I agree that that expansion tank saves on the seals by not letting pressure build up in the case. Did any of the props you got out of me work on your setup? Good hearing from you again and glad to hear you have got good use out of the super speed master
  13. #13
    Black Creek WI
    Beauti is in the eye of the beholder I guess. Thanks for the reply
  14. #14
    Jul 2012
    Lufkin, Texas
    Actually there is another possibility, it could be “sunset” which is supposed to be sand metalflake with apricot shearline accent...
    Josh Peterson
  15. #15
    Black Creek WI
    What ever it is, I hate it, the bottom don't show much signs of use So dam ugly never got used much
  1. preping waxed resin
    By kytekeith in forum Fiberglass and Composites Discussion
    Last Post: 05-12-2012, 02:39 PM
  2. preping fiberglass for paint
    By 77sst in forum Fiberglass and Composites Discussion
    Last Post: 03-20-2006, 10:13 PM
  3. CLE Paint Re-finish? Best method?
    By LikwidCourage in forum Technical Discussion
    Last Post: 10-22-2004, 12:41 AM
  4. Sanding And Preping for GelCoat
    By Fibertron in forum Fiberglass and Composites Discussion
    Last Post: 05-28-2004, 11:14 AM
  5. most Durable Boat finish? Paint Vs. Gelcoat
    By Georgia Boy in forum General Boating Discussion
    Last Post: 08-09-2002, 06:36 AM
