Results 1 to 7 of 7
03-19-2018, 01:48 PM #1New Member
- Mar 2018
- Georgia
2003 Mercury 250 pro xs racing model question
My buddy has a 2003 250 pro xs on a bullet..the motor ran flawless until he pulled the gas tank to replace the bildge pump..now it cranks great cold and will run great but when we stop to fish after about 30min—1hr it will not start will spin over but will not hit..after trying to crank it if it sets for 20-30mins it will crank back up..we checked to see if it was getting gas and when we pulled the gas link loose it was under a lot of pressure and shot gas out of the end coming from the motor...and what size gas line does this motor use..I know it’s not 3/8 on it..any tips on what is going on with it would be greatly appreciated
03-20-2018, 06:26 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Gas shooting out would indicate a vent hose/fitting not allowing pressure to escape. The fuel hose from the factory is usually 5/16'' at the fitting on the pulse pump and a 3/8'' to 5/16'' connector located inside the rigging tube with 3/8'' hose to the fuel tank. Remove the anti siphon check ball from the pick up for good fuel flow.
03-24-2018, 10:42 AM #35000 RPM
- Sep 2012
- Florida
- 441
- 15
- 9
- 84
03-25-2018, 08:55 PM #4New Member
- Mar 2018
- Georgia
It could be a 250 xs instead of a pro xs it just has mercury racing written on it also if this helps
03-26-2018, 10:23 AM #5Member
- Mar 2011
- austin texas
- 64
It is a 250xs. The proxs didnt come out until 2007 or 2008.
03-26-2018, 10:25 AM #6Member
- Mar 2011
- austin texas
- 64
Try pushing the little valve stem on top of the vst next time. See if fuel comes out or air. It could be boiling off. The primer would act like a check valve and the pressure would build. Still should start though.
03-26-2018, 09:14 PM #7Member
- Oct 2002
- Yantis, TX
- 93
3/8" fuel tank to primer bulb, 5/16" primer bulb to pulse pump inlet.
"We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing."
Hallett 26 foot model 7.9exp with dual 2.5 mercury racing outboards
By Flint b in forum Hulls larger than 20'Replies: 2Last Post: 11-13-2016, 11:21 PM -
2003 Mercury 250EFI Question
By rockettman in forum General Boating DiscussionReplies: 7Last Post: 11-21-2008, 10:05 PM -
Mercury Racing 2003 Catalog Now Online!
By Scream And Fly in forum General Boating DiscussionReplies: 1Last Post: 02-28-2003, 06:40 PM -
By Scream And Fly in forum Technical DiscussionReplies: 0Last Post: 02-28-2003, 04:54 PM
