Results 1 to 13 of 13
    May 2016
    Bean Station Tn.
    Exhaust divider ?
    The first Mercury I started building Bridgeport and it had some land and sea heads (dual plug) whoever had it before me fabricated a exhaust divider plate to hold all of the extra coils.... when I sold the heads of course that went with it so I got an exhaust divider plate that is two separate pieces from a local marina ( I cut on it a little bit to get rid of the clamshell cowl brackets ) but all the holes line up and it looks like it's going to work great.....
    Now that I've started getting all the parts together and preparing to build a 2.5 ...245hp... I noticed that that divider and plate are all one solid piece.... I know it's taking me forever to get to it but my question is. Is there a difference between the one piece and two piece plates are they interchangeable between the Bridgeport and the 2.5 .... and should I try to find one off of a performance motor for the Bridgeport or does it not really make any difference ??? I'll post a picture of the plate from the 2.5 now and when I get to the shop in the morning I'll post a picture of the two-piece plate that I shaved all the mounts off of ....
    As always thank you guys for all your help !!!!
    I know I ask a lot of questions but I'm trying to learn all I can and I do my best to research on the internet before I ask stupid stuff lol
    2.4 and 2.5 dividers don't inter change.
  3. Thanks 91eagle thanked for this post
    May 2016
    Bean Station Tn.
    .Thanks for the information... other than the different style Mounts for the cowl is there a difference between like a 260 2.5 divider plate and just the average fishing motor 2.5
    May 2016
    Bean Station Tn.
    ... this is the one I planned on using on the bridgeport....its off a 2.4 fishing motor but I cut off all the clamshell mounting brackets sticking off of it.... I looked for a while and couldn't find one for a Bridgeport that came off a performance motor only found ones like from the fishing Motors
    TX......somewhere?
    I don't remember ever seein' any divider plate/plates, pre "fat block" 2.0/2.4, production or hi perf (Bridgeport, oval port, formula), that DIDN"T have tha clam shell brackets on 'em.. and I've seen/owned lotsa of 'em.................
    May 2016
    Bean Station Tn.
    Maybe thats why I couldn't find any lol....
    Sep 2006
    Late 80's with the one piece cowl?
  9. #8
    May 2016
    Bean Station Tn.
    Not sure
  10. #9
    TX......somewhere?
    Quote Originally Posted by coffeeguy View Post
    still had tha ears............ they might have went away with tha water cooled regulator but it would have tha coil plate like all tha later models so coils would not bolt straight to divider......... in other words if coils mount direct to tha plate it will have ears.
    even tha hi perf. bungee strap cowl 2.0/2.4 motors had 'em.
  11. Likes 91eagle liked this post
    May 2016
    Bean Station Tn.
    I spent a few months looking for a part that they never made lol......well at least I know now
    TX......somewhere?
    if ya don't like 'em a cut off saw, fine file, sandin' with a little elbow grease and walla!............
  14. #12
    Sep 2006
    Water cooled regulator for sure has no ears.
    Would the coils run cooler when plate mounted?
  15. #13
    TX......somewhere?
    donno?.. never had a coil problem in all these years.. but can't remember "not" havin' coils mounted ta tha plate (divider) on anything I've had other than 280's............
  16. Thanks coffeeguy thanked for this post
  1. Mercury Tech: exhaust divider
    By rock in forum Technical Discussion
    Last Post: 07-22-2017, 02:35 PM
