Results 1 to 15 of 24
    Mar 2005
    tulsa, ok
    Mercury XR4 question
    Has anybody ever seen one of these motors with only 90 lbs of compression on all cylinders? I had one and it had 120+ on each cylinder.
    My cousin just bought this motor. It runs great once it warms up, but man, what a bear to start and warm up.
    I think it has been rebuilt and has the wrong heads on it or thicker head gaskets than stock.
    What say you?
    '94 Bullet 20XD W/225 Merc ProMax
    May 2016
    Bean Station Tn.
    May just need a set of rings ...but slap a set of stock head gaskets on it and see if it was running thicker ones ....as fas as the idea of it having heads other than stock ....find the casting number on the heads and post it here I'm sure someone here will let you know if there the correct heads for it
    Florida Keys
    Check it with another gauge....
    '95 STV "The Blue Goose"
    May 2016
    Bean Station Tn.
    Quote Originally Posted by mach351 View Post
    Good idea he has id suck to build a motor cuz your gauges off 30 lb
    Feb 2014
    Missouri
    Maybe incorrect testing? Did he bump the needle 3-4 times or crank it till it wouldn’t go up more?
    Mar 2005
    tulsa, ok
    It has been tested with 3 different gauges and all 3 read the same thing. If it needed rings, what are the odds that all 6 cylinders are worn equally and compression has deteriorated uni formally?
    Pekin, IL
    I can't imagine all 6 holes being down due to wear but spose anything is possible. It could have a set of uncut 2.5 heads on it with 1.25 gaskets. I have ran 2.5 heads (cut) on a 2.4 many times before but usually have to shave a bit of the width for them to fit which would show on the exhaust side of the head unless they were painted afterwards. If they are 2 piece heads ignore this post.
    Rock
    Team Junk
    Sep 2015
    Twin Cities, Minnesota
    Hard to imagine anyone would put extra thick gaskets on a 2.4 with stock heads and stock motor. probably just tired, had a bad water pump now and then creating hot cylinders cracking a ring possibly.
    TX......somewhere?
    never seen thick and thin 2.4 stuff... least not available to tha public?.. not even tha "fat block xr4"?.... had a bp that went down ta 80/85 lbs on all after beatin' tha **** outta tha thing for several summers.....
    Pekin, IL
    [QUOTE=tlwjkw;3029070]never seen thick and thin 2.4 stuff... QUOTE]
    Been workin on 2.5 stuff too long I guess. I just assumed you could get either. I could still see a 2.5 head easily causing lower compression.
    Rock
    Team Junk
    Mar 2005
    tulsa, ok
    I think I'm going to have to get a leak down tester, my curiosity is killing me.
  12. #12
    TX......somewhere?
    "I could still see a 2.5 head easily causing lower compression."
    yeah, there are a few of those out there now days.. don't really understand tha reasoning behind it though unless that's all ya got ta work with... even saw where someone actually cut center mains onna bp efi front half ta use onna 2.5 block.. don't see how that will work out though?
  13. #13
    Mar 2004
    vonore tn.
    I would try POWERTUNE before disassembly, It might be carboned up, that might give good indication of possible problem.
  14. #14
    Florida Keys
    I guess my next question would be if it’s turning over fast enough. Battery going south? Like said earlier, every hole worn the hell out is possible, but unlikely.
  15. #15
    TX......somewhere?
    that's cause most motors ya read 'bout on here never have a chance of jus "wearin' out".........
  16. Likes 90 5.0, billybob liked this post
  1. 2.5 Mercury question
    By Bassin72 in forum Technical Discussion
    Last Post: 07-15-2015, 06:30 AM
  2. Mercury 2.4 200 question
    By merc01 in forum Technical Discussion
    Last Post: 05-08-2014, 07:24 AM
  3. Mercury ECU question
    By dpf-01 in forum Technical Discussion
    Last Post: 07-07-2013, 02:26 PM
  4. mercury question
    By stvmike24 in forum Technical Discussion
    Last Post: 05-25-2004, 11:08 PM
