Results 1 to 11 of 11
03-18-2018, 01:39 PM #15000 RPM
- May 2004
- Eastern PA
- 594
- 29
- 54
Need Recommendations for Seat Mounting - Allison
Doing a period-correct (to the extent practical) restoration of a 1979 Allison GT-20. Just got it back from Jack’s place in FL and have a bare floor to work with. I have the original low back bucket front seats which have been recovered and look great. I don’t want to screw the seats directly to the floor...I’d rather use a platform of some kind (that can be permanently mounted to the floor) and mount the seat to the platform w/ bolts, thereby allowing removal when needed.
How are you guys mounting seats that can easily be removed and then put back without making your floor into “Swiss cheese”?
Thanks
03-18-2018, 06:06 PM #2Member
- Dec 2015
- Douglas Lake, Tn
- 79
- 27
I just picked up a pair of these to mount the seats in my Liberator. Just what you were talking about, Swiss cheese into the balsa core is correct. I'm hoping to be able to remove the seats to get under the deck easily. I'll let you know how they worked as soon as I install them.
Springfield Marine Boat Removable Seat Mount 185969
03-18-2018, 06:09 PM #3
Can you get to the bottom of the floor? if so, stainless T-nuts.
03-18-2018, 09:52 PM #4
Someone turned me on to these many years ago and they are great for seat mounting. Very strong and keep in mind that your going to use 4+ so the strength is much greater than the individual pound rating. Can't remember the exact size but just get the largest screw in stainless!
http://www.toggler.com/products/snaptoggle/overview.php
03-18-2018, 10:27 PM #5Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
Look into these. I haven’t used them but others on the site have.
http://www.weldmountsystem.com/produ...less-studs.php
Another option is to fiberglass an aluminum or stainless plate to the floor. Have studs or threaded holes in the plate.
Made aluminum plates with threaded bosses that the seat can bolt to. Going to glass them in. The advantage of a threaded boss is you can do varying heights to make the seat angle as you like.
03-19-2018, 09:54 AM #6The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
Hole-saw a hole big enough to reach through & thru-bolt with stainless locknuts & double stainless flat fender washers. Hole saw the floor and the plate.
03-19-2018, 02:12 PM #7
Good idea can you post a link where to buy those
03-19-2018, 02:25 PM #8
I used to glass a piece of 3/4" plywood same size as seat bottom to floor with t-nuts. last for a long time if done correctly and you don't have to drill your new floor
03-19-2018, 02:29 PM #9The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
Note; My idea will not work, if you first determine there is not enough room under the floor panel, to at least, slide in a wrench, washers & nut. So check this out first before cutting anything. Amazon & Ebay both show each slide assembly at about fifty dollars each, shipped. Great Lakes Skipper at thirty-five dollars each, plus shipping. May the force be with you.
03-19-2018, 02:39 PM #10The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
Another method to consider "before" glassing down a new floor, is to pre-determine seat & seatbase locations...and glass a piece of 3/8'' aluminum, that has been drilled/tapped, under the floor panel. I've glassed in small pieces and large full-size aluminum sheet, depending on style of boat(stand-up bolsters & frames, bucketseats, etc...)
XstreamVking liked this post
03-19-2018, 03:15 PM #11Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
You can glass some 3/8'' alum into the floor on top too. Just drill and tap for the seats to screw down into after glassin.....Plenty strong and will not stick up at all if you recess them flush into the floor before glassing.
Four seat tunnel for dad... recommendations?
By HydroStream6 in forum General Boating DiscussionReplies: 34Last Post: 07-07-2017, 08:56 AM -
Allison XB2003 bucket seat covers and rear bench seat
By catfish123 in forum Misc. Parts and AccessoriesReplies: 2Last Post: 08-20-2013, 08:00 AM -
Seat sliders recommendations
By rujr in forum Technical DiscussionReplies: 1Last Post: 07-01-2013, 08:17 AM -
Seat mounting ??
By fastcat in forum Props, Setup, and RiggingReplies: 5Last Post: 05-02-2010, 10:40 PM -
seat mounting
By Wild Bill in forum General Boating DiscussionReplies: 0Last Post: 04-20-2007, 10:20 PM
