Results 1 to 13 of 13
    Massachusetts
    Mercury 2 ram trim clamps
    I have 2 old school mercury v6 2 ram clamps for sale. Make offer...need em gone
    I have pics of one...other i need to separate from can.
    Pm or text @ 5082923506
    -Josh
    1989 Hydrostream Vector "Spongebob" 78mph
    1980 Hydrostream Vector "Ole Blue" 104mph
    1982 Allison GT20 "Red Eagle" 92mph
    1977 Hydrostream Viper "Hornet" 105mph
    1990 Mirage Jaguar 106mph
    1989 Hydrostream V-King YT "White Lightning" 91mph
    1991 Stv Procomp "$hitbox" 90mph
    Dec 2011
    Ludington michigan,on the shore
ID:	401965Those are the best ones!!!
    GA
    Dang You couldn't blow the leaves off before the pictures? LOL GLWS
    Black Creek WI
    Quote Originally Posted by outasite View Post
    Why do you feel that way? What in your opium makes them the best? Only asking because I have a few and am wondering if i'm missing out on something by not using them
    1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
    GA
    Quote Originally Posted by wogi View Post
    Good question. I always thought the singles were the way to go.
    Black Creek WI
    I know that on the two ram brackets, two of the bolts in stock form were hollow and the power trim lines feed threw them, also the transom bolt pattern to the boats transom was different than any others
    Jul 2012
    Lufkin, Texas
    They’re the lightest by far, stronger than a 3 ram, they’re FAST with the right pump. OMC sterndrive pump should do the trick. Clean setup if you can run the lines through the transom too! Very nice for a small light boat that doesn’t need any setback. You can mount it on a plate if you run the lines externally.
    Josh Peterson
    Dec 2011
    I could not have said it any better.You just described exactly how I run mine.The only negative is the bolt pattern is different.Set the two side by side and look at what it takes to build each one,then you will understand why Merc went with the single!
    Jul 2012
    Lufkin, Texas
    You told me how to set up mine a few years ago so I can’t really take credit!
    Josh Peterson
    Dec 2011
    Oh,one other thing,they come with provision for a second steering cable.No kit needed.
    Black Creek WI
    Thanks for that info guys, just started a new v-king project and have a brand new omc sterndrive pump, thinking I am going to give this stet up a try on that boat, Guess I just never had a open mind to using a twin ram before now.
  12. #12
    Massachusetts
    I would use it but i dont feel like redrilling my jackplate lol
    Bob if you want it i can bring to the romp
    Best offer takes it
  13. #13
    Mar 2004
    Brooklyn Park, MN
    If i cannot find cables for my Vking, I was going to put a seastar system on my 1978 merc. I think all I need to do is grind off the 2nd steering tube holder that Bob is talking about so that the ram can get to the tilt tube. Anyway, easy to drill the plate. Bolt the bottom 2 holes on the clamp to the plate, they I think are the same width apart as a newer BIA clamp. Then once you have it centered and secured with the bottom two bolts drill the top holes.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  1. Mercury 3.4 20" driveshaft housing, clamps, and trim ram
    By bernie in forum Misc. Parts and Accessories
    Last Post: 04-28-2016, 04:24 PM
  2. 3 liter Merc mids 25 in with offshore clamps and trim
    By 87vantage in forum Misc. Parts and Accessories
    Last Post: 10-15-2014, 10:39 AM
  3. Mercury Tech: clamps
    By bigboy in forum Technical Discussion
    Last Post: 09-25-2008, 05:38 PM
