Results 1 to 6 of 6
    Mar 2018
    Houston, Texas
    1995 Mercury 225 Leak from Driveshaft Housing
    I recently purchased a boat with a 1995 Mercury 225 3.0L Carbed version.
    It had been sitting for at least 7 years with old gas. The carbs were like molasses.
    I cleaned everything up. New carb kits. New impeller kit.
    The motor cranks and runs now.
    This weekend I took it to a boat ramp and submerged the back end. Let it idle for about 5 minutes. Revved it in neutral a time or 2.
    Pulled it back up the boat ramp to inspect and noticed a leak at the bottom of the drive shaft housing on the starboard side. (See pics.)
    Looked like the gear oil had mixed with water to create a grayish sludge.
    I'm thinking it's probably a seal in the lower unit. So I ordered this gear housing seal kit:
    http://www.marineengine.com/newparts...ER26-816575A+5
    Is there anything else you can think of?
    Should I consider replacing anything else?
    One more point, the oil pump has been removed and so I'm manually pre-mixing 2 cycle oil in the gas at a ratio of 1:50.
    The engine smokes quite a bit at idle.
    Is there anything additional I might consider to reduce the smoking?
    Thanks in advance for your consideration!
    Doubt its gear lube, sat for 7 yrs probably just cleaning all the crap that settled in the mid. Change the gear lube and try it again.
    May 2017
    Ca
    Could be the lower crank seal drainin oil from the crank case down the mid. Had to replace the seal on my optimax
    Mar 2018
    Houston, Texas
    Thanks for the input Guys!
    In addition to the lower gear house seal kit, I'll go ahead and order an upper/lower crank seal kit. And just replace them all while I'm at it. It can't hurt after sitting so long in the HOT Texas summers.
    Any additional ideas are greatly appreciated.
    May 2017
    Ca
    Quote Originally Posted by mitche View Post
    right on. Might want to order a power head gasket because u gotta pull the ph off the exhaust plate.
    Mar 2018
    Houston, Texas
    Thanks Bunger! I'll definitely add the power head gasket to my purchase order.
    Really appreciate the advice!
  1. Mercury Tech: 1995 Mercury 200 XRi - Idling with Bleed Hose Leak and Clicking - Video
    By mram10us in forum Technical Discussion
    Last Post: 04-03-2015, 10:30 AM
  2. Mercury 2.4l driveshaft housing 20" nla
    By Cal 47 in forum Misc. Parts and Accessories
    Last Post: 03-17-2015, 08:07 AM
  3. Mercury / mariner 2.5 driveshaft housing 20"
    Last Post: 03-17-2015, 08:00 AM
