Results 1 to 6 of 6
Thread: V6 yamaha carb tuning
03-14-2018, 08:44 AM #1Member
- Nov 2012
- Tillsonburg
- 89
i have been playing with a 2.6 yamaha and have been looking for some 34 or 36 mm carbs with no luck. I have a set of single float 32mm carbs that i would like to use until i can locate the right ones as the season is approaching and i just picked up a boat. The engine had some port work, tight heads (approx 130psi), horizontal reeds, 225 excel tuner and exhaust divider. Also has finger ports. Ive built it from parts i bought here, heads are hydro tec.
How do these old yamaha carbs work in terms of tuning? I can see that yamaha had different size carbs on the same block for the 150, 175, and 200. If i run these 32 mm carbs from a 1987 200 will they be lean? Should i jet up?
Im thinking that they will obviously restrict the motor and not allow it to make full use of the mods but shouldnt the carb run at the correct AF mixture regardless of whats behind it? I could be completely wrong and would like to hear from some yamaha guys.
03-14-2018, 09:10 AM #25000 RPM
- Dec 2005
- Valrico Fl.
- 564
Any time you add more compression and or ignition timing you will need to add fuel , jet up . I would start with a couple sizes larger jet than make a few wot runs read the plugs and piston tops and give that yamaha what it is asking for . You can tune both the carbs but may see a little more RPM with the larger carbs when tuned correct . Joe R
03-14-2018, 09:21 AM #3Member
- Nov 2012
- Tillsonburg
- 89
03-14-2018, 01:56 PM #45000 RPM
- Dec 2005
- Valrico Fl.
- 564
I would go up the two sizes on your main jets . You may be able to buy used in smaller sizes than drill them out . Also hydro tech may have jets .
03-17-2018, 02:37 PM #5
Find an outboard salvage yard. Best place for jets.
03-17-2018, 02:55 PM #6Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
So you're the guy who's made all those carbs useless! LOL
Mercury Tech: Carb tuning questions
By Slimm in forum Technical DiscussionReplies: 14Last Post: 07-08-2017, 06:26 PM -
WMH carb tuning
By crazy cajun 2 in forum Technical DiscussionReplies: 5Last Post: 01-07-2008, 12:08 PM -
tuning 2.5 carb
By 235spd liner in forum Technical DiscussionReplies: 0Last Post: 06-10-2007, 06:51 PM -
Modified Looper Carb tuning?
By B.Mac in forum Technical DiscussionReplies: 32Last Post: 02-23-2004, 12:48 PM
