Results 16 to 30 of 67
Thread: 2 Cycle Oil
03-13-2018, 08:31 PM #16
This is for all OB oils.
The biggest benefit of synthetic lubricants technology is realized in crankcase lubricants. For example if you try to start an engine at the north pole, a synthetic based lubricant will resist the extreme cold better. Same goes for extreme heat. Or extended change intervals.
None of these conditions exist when the oil is burned with gasoline.
And BTW- I use the cheapest (any brand) motor oil that meets the current spec for the application. For common crankcases it's SN for gasoline and CK for diesel. If it meets the spec who cares what the label says? Yes really!
03-13-2018, 08:43 PM #17Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I thought the synthetic re extreme heat makes it like castor oil in that a severe friction point in the engine might survive with these oil but not with conventional oils?
tcw only tested on stock engines under 6k to meet the spec.
03-13-2018, 08:44 PM #18Member
- Jul 2017
- upstate ny
- 47
- 7
From what I've read sn might not be better than sl rating...something about flat tappets like additives like zink and phosphorus, sulpher and such but cat converters not so much. What do ya know about this? Will a synthetic 4 stroke oil mitigate the lack of additives as so far OB's don't use cats..
03-13-2018, 08:50 PM #19
Brother there's always a hole in paradise... lubricants are improved and therefore the specs are revised and updated to meet the needs of the general public. I can't address the needs of extreme high performance engines but I expect... the needs do not differ from the engines that they are derived from.
BTW- There's a whole generation of SM spec between SL and SN.
03-13-2018, 09:04 PM #20Member
- Jul 2017
- upstate ny
- 47
- 7
Actually I got that info off an antique auto forum..but I think most OB''s use flat tappets..
...just used sl for an example..
Ya..original post about 2 smoke oil but just had to ask while I had a chanceLast edited by rudderless; 03-13-2018 at 09:07 PM.
03-13-2018, 09:19 PM #21Member
- Jul 2017
- upstate ny
- 47
- 7
Remember that commercial many years ago about their new synthetic motor oil? They started 2 autos and drained the oil while running and the synthetic oil equipped auto ran much longer before seizing.. was like 40 year ago...
Oh...your present location says you probably haven't
03-13-2018, 09:21 PM #22Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
other then the down side of castor oil it beats the extreme friction spec of all of them, biodegradable and renewable
03-13-2018, 09:26 PM #23
OK I can always learn. It's bio and renewable. What's the downside?
And what friction spec is it beating?
03-13-2018, 09:33 PM #24
03-13-2018, 09:50 PM #25Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Purple
03-13-2018, 10:03 PM #26
Used it plenty in the past. It's priced well past it's usefulness now.
03-13-2018, 10:08 PM #27Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
most things are now
03-13-2018, 10:24 PM #28Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
03-14-2018, 09:07 AM #29Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Big league chew
03-14-2018, 09:15 AM #30
Hmm...
Repower Boston Whaler 255 - single or twin, 2-cycle or 4-cycle?
By Skytour in forum Technical DiscussionReplies: 19Last Post: 05-06-2010, 08:47 AM -
How to pre mix 2 cycle oil?
By studioDog in forum Technical DiscussionReplies: 23Last Post: 06-24-2008, 10:33 PM -
2-cycle VS 4-cycle lower units -OBs
By Techno in forum Technical DiscussionReplies: 3Last Post: 09-26-2007, 08:40 AM -
2 Cycle Oil
By jumpdogg909 in forum Technical DiscussionReplies: 3Last Post: 09-26-2006, 05:56 AM -
2-Cycle oil?
By CNT in forum Technical DiscussionReplies: 5Last Post: 04-07-2005, 05:43 PM
