Results 16 to 21 of 21
Thread: 300 promax tuner
03-20-2018, 06:03 AM #166000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
03-20-2018, 08:26 AM #17
My bad , I thought you made a statement . Theorized from the compilation of your readings ...
"Just" cutting the inner liner will give the exhaust a larger area to expand in before it meets the same "total exit area". There is room on the bottom of the cavitation plate behind the back set of 12mm studs to drill a few .625" holes .
It will be quiet @ idle and move enough air at WOT to be happy .
The tuner leave's a bit to be desired . But if your going to take the time to take the mid all apart you might as well spend a few hours correcting core shift and get rid of the casting (&%&**(()% in the runners .
03-20-2018, 01:33 PM #185000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
03-20-2018, 01:51 PM #196000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
03-20-2018, 01:53 PM #206000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
I had to take it apart to cut 5" from the water tube and degrease and paint it, had some salt use at some point, i see where you mean to drill holes in can
03-20-2018, 02:05 PM #215000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
Promax SS tuner or Bridgeport Tuner
By Go Time in forum Parts WantedReplies: 8Last Post: 04-19-2016, 09:56 AM -
Promax 225, which exh. Tuner ?
By Varmint in forum Technical DiscussionReplies: 14Last Post: 08-26-2015, 12:32 PM -
Does 300 promax tuner
By Skater 32 in forum Technical DiscussionReplies: 0Last Post: 03-13-2010, 03:42 PM -
300 promax with mad efi tuner
By draeger in forum Technical DiscussionReplies: 7Last Post: 10-21-2007, 12:20 AM -
225 promax tuner
By motion in forum Technical DiscussionReplies: 2Last Post: 02-11-2003, 11:22 PM
