Results 1 to 13 of 13
    New Smyrna Beach, FL.
    Custom 15' Wahoo "whaler copy"
    15' Wahoo with bottom re-worked and running pad added by Doug Wright. The entire deck joint was glassed and filled, the seat back/bulkhead was added and everything in the boat was replaced. Rigging includes: Livorsi steering wheel, shifter, gauges, Garmin G.P.S., billet fire ext., all new wiring, hyd. steering, jackplate, stainless taco rubrail, and recessed cletes. The boat handles extremely well, runs flat and stable. This is a one off deal and being sold for a fraction of what was put in it. Price is $6500.00 for hull and rigging -no motor or trailer.
    386 527 1845Click image for larger version.
ID:	401326Click image for larger version.
ID:	401327Click image for larger version.
ID:	401328Click image for larger version.
ID:	401329Click image for larger version.
ID:	401330Click image for larger version.
ID:	401331Click image for larger version.
ID:	401332Click image for larger version.
ID:	401333Click image for larger version.
ID:	401335Click image for larger version.
ID:	402094Click image for larger version.
ID:	402095Click image for larger version.
ID:	402096Click image for larger version.
ID:	402097Click image for larger version.
ID:	402098Click image for larger version.
ID:	402099Click image for larger version.
    If someone is able to correct the picture rotation, that would be great.
    Dec 2011
    St. Pete, Fl
    Joe, that's a really cool boat. How did it run with the 15" 115 opti?
    Brian
    19 Reaction 150 Pro XS
    21 Checkmate 250 Pro XB (sold)
    25 Talon Carrier (sold)
    24 Predator 300x (sold)
    21 Talon 225 3.0 liter (sold)
    18 Talon 2.4 Bridgeport (sold)
    It has seen a best of 60 and cruises great at 50. This is not a light boat so it tracks really well, stays straight, and runs level on the pad.
    Mar 2010
    Miami FL, Keys
    My 15 whaler ran 55 with a 75 Yamaha, how much heavier is this boat? How big is the gas tank? Any other picture of the interior?
    24' SKATER Twin 15" DBR 300xs w/Carbon Fiber Aliens
    21' RALLY SPORT 300 MERC (sold)
    15' SS Whaler 75 Yamaha (sold)
    The fuel tank is 12 gallons and is built into the seat with an external side fill. I don't what it weighs but there is a lot of glass in this little boat compared to a production whaler. I have had a bunch of whalers "have 4 now" and know enough to be able to compare the two. My goal when I did everything to this boat was to make it a very easy to drive rig that my 11 year old would have fun running and be able to air up on the pad. I will get some interior pictures added to the post.
    Pictures added.
    Will sell the trailer with boat for a few extra bucks.
    $6500.00
    Feb 2003
    Punta Gorda, FL
    Just sold a 15 Whaler Sport with a 60 4 stroke Mercury and galvanized trailer for $9K.
    The hull weighed 950lbs. Great little boat that ran a max of 40 mph.
    There was more money spent on the following then what I am asking:
    Doug Wright adding the pad and working the bottom
    Livorsi shifter
    Garmin GPS/Chart plotter
    fiberglass/carbon fiber/epoxy/primer and paint
    The boat, Randy Corson rigging, hyd. steering and helm, livorsi gauges, bezels, fire ext., pop up cleats, lights, rub rail, hull itself, new teak, new hyd. lines, new shift & throttle cables, duel blinker trim switch and billett hardware are all free.
    Sep 2008
    charlestown, ri
    How did you get it to run 55 with a stock 75? Was that GPS because with my 88 v4 omc I could barely scrape 54 on gps. One hell of a hole shot though!
    Ttt
  12. #12
    Mar 2010
    Miami FL, Keys
    Quote Originally Posted by Revenge22 View Post
    That’s just what it would run light on fuel had a GPS that showed speed, it was a two stroke 75 Yamaha bought the motor new, think it was a 1996
  13. #13
    Sep 2008
    charlestown, ri
    that's impressive! low weight helped, I'm sure. I never ditched the 21"" aluminum on mine. should've tried a 20"" raker.
  1. new project--13 whaler copy
    By mackeral5 in forum General Boating Discussion
    Last Post: 11-23-2009, 10:01 AM
  2. check out my chinese outboard "yamaha copy"
    By MJ POWERSPORTZ in forum General Boating Discussion
    Last Post: 08-31-2009, 08:11 PM
  3. Whaler "Green Line" seperating
    By blkmtrfan in forum Fiberglass and Composites Discussion
    Last Post: 05-23-2006, 07:39 AM
  4. 17' Boston Whaler "Blown bottom" project
    By AlaskaStreamin in forum Fiberglass and Composites Discussion
    Last Post: 03-25-2004, 12:44 AM
Bob's Machine
