Results 1 to 3 of 3
    Oct 2017
    Turks & Caicos IS.
    Larson Wildfire Setup
    Hey guys im new to this fourm im from Turks and Caicos Island, need lil help setting up my larson wildfire/Senza got a 200 merc on it with a 6" manually jackplate not seeing much if any of these boats on this fourm any advice on what prop i should be running trying to get the most out of this little thing...Thanks in advance any help would be appriciated
    Feb 2003
    Rochester, NY
    If that's the hull I think it is, it was called the Senza up here in the states and was just over 16 feet long. I had a 1984 model with a 115 HP straight six Mercury outboard on it and the best I ever saw was 58 MPH.
    Based on my experience, I'd look for / do a few things to it. First, check the last 4 feet of the hull for hook. Mine had a ton and it scrapes speed off pretty effectively. Second, reinforce the transom big time. I had mine done after I fractured it pretty badly. In fact we ended up building a set of knees for it and glassing them in. Remember, that's a chopper gun layup hull and it's not designed for nearly the kind of power you have on it. (I think mine was rated for a maximum of 125 HP.) When I sold mine after 3 years, the boat had stress cracks from bow to stern.
    BTW, what kind of steering setup do you have? Anything less than hydraulic steering is going to make that thing a death trap.
    1992 Progression 22
    Mercury Racing 250R
  3. Thanks t33j649 thanked for this post
    Oct 2017
    Turks & Caicos IS.
    Thanks for the information @TooStroked I'm running a hydraulic stseeing the boat was recently restored previous owner had a 225 ocean pro on it
  1. 16ft Larson Wildfire adding a pad
    By RonnieLittle in forum Fiberglass and Composites Discussion
    Last Post: 07-11-2011, 10:56 PM
  2. 16 ft Larson Wildfire
    By RonnieLittle in forum Appearance Mods
    Last Post: 08-21-2010, 10:24 PM
  3. 1982 Larson Wildfire 5000
    By stcroixjoe in forum General Boating Discussion
    Last Post: 01-23-2010, 09:05 PM
  4. Larson Wildfire help
    By joegucci in forum Technical Discussion
    Last Post: 08-18-2009, 01:42 AM
  5. 1980 Larson Wildfire 5000
    By romanowichm in forum Technical Discussion
    Last Post: 03-26-2008, 09:47 AM
