Results 1 to 7 of 7
03-05-2018, 07:16 AM #1Junior Member
- Mar 2018
- Florida
- 7
1997 200Hp Johnson Ocean runner carb jet question
Hello all. First post, just discovered this site. I'm not a racer, but having trouble with my new to me J200TXEAU. It was idling poorly, surging and misfiring at idle up to about 3500rpm, then would take off up to 5500 smoothly. I have gone over the systems using the shop manual, and found all 6 exterior check valves in the recirculation system open (no valve) and all six internal valves missing. Obviously someone had been inside this motor. Anyway, set all up by the book, link & sync, etc. Idle timing at 4 ATDC. runs much better, but still searching a bit at idle (1000 in neutral, 650 in gear), and the range from 1000 to 2000 is rough and surging. Stock low air jet is 27. I'll verify that today. Any suggestions on a jet to run richer through that range? Anyone willing to loan me some different sizes to try? Thanks for any help.
03-05-2018, 04:58 PM #2Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Original 97 carbs have an adjustable idle needle. Start at 5 and a 1/2 turns out. Should be TXEUA not TXEAU
03-05-2018, 09:57 PM #3Junior Member
- Mar 2018
- Florida
- 7
You're right. Typo, EUA. 51/2 is where I started with the mixture screws. I went +/- a half turn with each carb individually but couldn't really detect a difference. I'm going to go over it again looking for air leaks. How many turns should I go on the mixture screws before giving up?
03-05-2018, 11:16 PM #45000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
seem's 7-71/2 in heat of summer is about what I end up setting them at ---(normal??)-th
03-07-2018, 05:01 AM #5Junior Member
- Mar 2018
- Florida
- 7
Thanks. I just replaced the cam follower, the outer part was broken off. My setup must have been off though, because it ran worse afterwards. Stalled out a couple times trying to dock. Re-checked the idle and sure enough, the timing was retarded too much. Brought it back to 4ATDC and it idled fine, but still a misfire/sneeze. More work (playing around) to do today. Looks like the mixture screws have a wide range.. If I go from 5 1/2 turns to start out to 7 1/2 in 1/8 turn increments X 6 carbs, it's gonna take awhile.
03-07-2018, 07:00 AM #6Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
If you had set your timing before and now it was different make sure the ctr hub has not moved. Go 1/4 at a time till close.
03-08-2018, 04:24 PM #7Junior Member
- Mar 2018
- Florida
- 7
Did a thorough link and sync today. 650 idle at 2° ATDC. Much better. Still a bit rough below 2000, but maybe I expect too much. Settled at 5 turns and gave up for now. Thanks for all your help, appreciate it.
good or bad '97 250 johnson ocean runner
By CircleHook in forum Technical DiscussionReplies: 1Last Post: 02-10-2015, 09:17 PM -
95 johnson 175 ocean runner
By lxman88 in forum Outboard EnginesReplies: 8Last Post: 09-12-2014, 11:39 PM -
1999 225 Johnson Ocean Runner - Increase performance question
By johnson1 in forum Technical DiscussionReplies: 5Last Post: 07-10-2014, 08:09 PM -
98 Johnson 175 ocean runner
By hevysrf in forum Technical DiscussionReplies: 2Last Post: 03-04-2004, 12:31 AM -
96 johnson 175 ocean runner problem
By hydrasportfish in forum Technical DiscussionReplies: 2Last Post: 01-06-2004, 11:01 AM
