Results 1 to 8 of 8
03-05-2018, 01:54 AM #1Junior Member
- Mar 2018
- Kaiapoi, New Zealand
How to change gear oil on evinrude super strangler
I have an evinrude super stranger and there doesn't seem to have a bottom bung to drain gear oil only two bungs above the cav. Plate
03-06-2018, 04:17 PM #2Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
I would think if you trimed it up most oil would come out the front screw. Then use Low pressure air to blow out some more. Low so ya don't blow the seals. Or get a oil pump for lower grease and pump till clean oil comes out. Is it a 1/1 lower or the big case?
03-06-2018, 04:32 PM #3Junior Member
- Mar 2018
03-06-2018, 06:23 PM #4Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
What boat is it going on? I have props if you need......
03-06-2018, 07:34 PM #5Junior Member
- Mar 2018
I have some props, but I will keep you in mind if I need one. Cheers
03-06-2018, 09:44 PM #6
Cool! Pics of motor?
03-08-2018, 07:13 PM #7
Take the box off, remove both plugs and stand the box on its drive shaft end. To refill, refit box and with the drive trimmed level refill through the lowest hole until oil runs out the other.
Popey
03-10-2018, 11:51 AM #8Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
What if time is short? And you can't pull lower.
Photos: Evinrude Super Strangler!
By Scream And Fly in forum General Boating DiscussionReplies: 248Last Post: 10-15-2019, 12:42 PM -
Evinrude Super Strangler? Racing Motor in Minneapolis!
By ChinewalkerII in forum Outboard and Racing HistoryReplies: 8Last Post: 04-28-2013, 07:59 AM -
Evinrude Super Strangler V4 - 4 Page Catalog
By Scream And Fly in forum Outboard and Racing HistoryReplies: 46Last Post: 02-20-2007, 11:43 AM -
Twister 2 or Super Strangler
By KG4 in forum General Boating DiscussionReplies: 15Last Post: 08-04-2002, 07:59 PM
