Results 1 to 14 of 14
03-03-2018, 11:12 PM #1
3/8" compression 90 degree elbow for hyd steering
21' Paramount
Mercury 300 Promax
03-03-2018, 11:15 PM #2
21' Paramount
Mercury 300 Promax
03-03-2018, 11:21 PM #3
And yes, Ill be taking care of the screws. Just mounted the fitting tonight.
21' Paramount
Mercury 300 Promax
03-03-2018, 11:43 PM #413' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
03-04-2018, 09:58 AM #5
Personally, I have never seen what you are looking for. You can get a 90 degree tube to tube double male and use a short piece of 3/8" copper tube (or stainless tube if you can find some) between the bulkhead fitting and elbow.
03-04-2018, 09:59 AM #6
If it exists, Hoser would know...
03-04-2018, 10:28 AM #7
Best bet would be to have a hydraulic hose guy put elbow fittings on the hoses.
03-04-2018, 11:05 AM #8
03-04-2018, 11:16 AM #9
03-04-2018, 11:26 AM #10Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Parker makes a screw in comp fitting in 90 I believe. Gotta go to a parker store though. May even make a swivel pc.
One Oldman liked this post
03-04-2018, 02:28 PM #11
That’s a SeaStar plastic/Kevlar hose with machine installed O ring end.
You need a reducing coupling 3/8 to 1/4 and use the SeaStar 90* with 1/4 pipe thread on one end or the HF 6400 ORB fitting.
03-04-2018, 03:14 PM #12
The bulkhead fitting is a 3/8" tube; same as the 3/8" tubing fitting that uses a ferrule. SeaStar uses the o-ring fitting for the hose. He simply needs a 90 degree fitting to replace what's on the hose or go with the way I described in post #5. Better to go with new fittings on the hoses than to add multiple fittings and have more chance of a leak.
03-05-2018, 06:15 AM #13
I see it! Seastar fittings are all O ring. Sure less is better but I believe Seastar does not have a 90* for the hose end and since is their fittings probably the only one that would be able to install for security/safety reasons if they did.
The other option is use a Seastar bulk head setup with 90* ends.
03-05-2018, 09:03 AM #14
I rerouted the hoses. All done.
Thanks13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
Hydraulic steering 90 degree fitting question
By mjw930 in forum General Boating DiscussionReplies: 18Last Post: 03-21-2018, 01:03 AM -
My take "lib Arts" or a "Masters" degree..
By Robby321 in forum The Scream And Fly LoungeReplies: 1Last Post: 01-08-2017, 11:46 AM -
Omc blocks and cranks 60 degree and 90 degree block made in england
By goodride in forum Misc. Parts and AccessoriesReplies: 0Last Post: 12-23-2014, 01:21 PM -
Finally figured out how to do a "Degree", symbol, keyboard!
By Robby321 in forum The Scream And Fly LoungeReplies: 41Last Post: 11-30-2010, 07:02 PM -
I need a 6" 90 degree aluminum condiut elbow ( sweep )
By Jay Smith in forum The Scream And Fly LoungeReplies: 14Last Post: 06-27-2006, 01:43 PM
