Results 1 to 11 of 11
Thread: Fuel oil mix ?
    May 2016
    Bean Station Tn.
    Fuel oil mix ?
    Wanted to get everybody's opinion on a few things....
    I just noticed the otherday that the Shell station down the street from the boat ramp I have always used sales the higher octane "race gas" or whatever it's called I think it's 110 octane I'll check and make sure tomorrow..... what's the benefits to switching to the higher octane is it worth the added cost and do you switch up the premix or mix it the same as you would 93...... and just add to the conversation what oil do you guys use and what's the mix ratio in the 2.4 and 2.5 Mercs
    shreveport,la
    There is no benefit to using a higher octane fuel than is required by your compression ratio and timing. In fact, it will hurt power.
    Erik Kiser
  3. Thanks 91eagle thanked for this post
    May 2016
    Bean Station Tn.
    Quote Originally Posted by patchesII View Post
    .... I'm having a motor put together now that somebody had did a lot of machine work and the exhaust chamber the heads were land and sea and I sold them once I get it together of course I'll do a compression test but... what I'm asking is What compression would you recommend using the higher octane... I don't want to use pump gas on something that would run better with the 110 or vice versa
    Thanks
    I would find out exactly what that fuel is first.
    Sarasota, FL
    93 oct is good for up to 145-150 lbs compression. If your not planning to drag race there really is no reason to have compression any higher than around 145-150.
    Rob Lankford
    1988 20' Action Marine 2.4 200
    Previous owned boats worth mentioning
    1976 17' Action Marine 2.4 200
    1984 20' Action Marine 2.5 200
    1983 17' Hydrostream V-King 2.4 Bridgeport
    2003 LPB STV RR COPY 2.5 280 /300 Drag
    2004 LPB STV RR COPY 2.5 280
    2005 Baja 23 Outlaw 6.2 Mercruiser
    2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
    2009 FTP Quarter Shot T3 Race 2.5 280
  7. Likes 91eagle liked this post
    Sep 2015
    Hodvpmdom
    When i want to go F with the deep pocket boys in their big macho bass boats and the ones in there wake boats. You know the ones i am talking about. I will pop on some 26cc heads which bring the pressure up to 195 to 205psi's and run the gas station 110 octane fuel. I'll use the Yamaha 26p drag prop because you know they ain't gonna hit 100+. But keep the 32 in the truck just in case. This is my not so stock carbureted chrome sleeve oval port 2.4 Mod VP motor. If I am gonna wind it towards 9k I usually run the oil about 18:1 If I am not gonna wind it to the limit, about 24:1. I also use Pennzoil Premium Plus. If your exhausting through your lower unit, don't expect it to be clean, Its gonna be very black and oily. And another thought that nobody really talks about. This high compression setup for 20 gallons and fuel consumption only costs me $225 for 45 minutes of fun. But its well worth it. Hope that helps a bit.
  9. Thanks 91eagle thanked for this post
    Likes 91eagle, powerabout liked this post
    May 2016
    Bean Station Tn.
    Does anybody know what cc the factory heads are on a 260 ..2.5 ..... or the heads on a 2.4 Bridgeport were from the factory ?...... and one more question that popped in my head but I didn't want to start a whole nother thread for it what is the paint on the top of the blocks mean I've seen several different ones and they all had a little spot of color of paint sprayed on top of the block the last one I got is got like a orange color....
    May 2016
    Bean Station Tn.
    Sarasota, FL
    Quote Originally Posted by 91eagle View Post
    Typically they were 38 cc factory. 34 cc is safe for pump gas. 32 and your cutting it close and need thick gaskets. The diff color spray paint spots are assembly/inspection sign off markings I believe.
    Rob Lankford
  13. Likes 91eagle liked this post
    Feb 2011
    HUDSON, FLORIDA
    absolutely and dont be told more is better.
    Feb 2011
    HUDSON, FLORIDA
    Quote Originally Posted by Krazymaan View Post
    my drag race nova costs me 6$ for 6.3 sec of fun!
  1. Clogged Fuel Line??? Difficult to pull fuel through fuel line.
    By supervetteracer in forum Technical Discussion
    Last Post: 04-30-2016, 09:08 AM
  2. Replies: 5
    Last Post: 06-01-2010, 06:48 PM
Simon Motorsports
