Results 1 to 13 of 13
Thread: Misc. Merc parts
03-02-2018, 01:48 PM #1
Misc. Merc parts
1 new set of 7 petal reeds (one reed block)
1 full set used merc reeds some good some bad
6 stock 2.5 rods 1 odd rod has slots at wrist pin end
20" 2.5 280 exhaust can drilled above cavitation plates has blue solid mounts in lower
6 used standard bore pistons (cleaned) message for pitures
1 piston ring set standard bore (2 rings)
3.0-3.2 liter lower steering yoke (steel) ..dirty.. not worn
3 liter aluminum shift shaft seal carrier with snap ring holds 1 seal can be bored to hold 2
misc. 2-1/16" gauges
7k merc tach
Make reasonable offer...... Paypal..... I will send.Last edited by 2.5-21; 03-02-2018 at 02:22 PM.
03-02-2018, 03:58 PM #2
$30 for the tack
03-02-2018, 04:31 PM #3
03-10-2018, 06:09 PM #4
Got it. Thank you
2.5-21 liked this post
03-14-2018, 10:41 AM #5Junior Member
- Dec 2016
- Dayton ohio
- 9
03-14-2018, 11:10 AM #6
PM sent
04-13-2018, 01:55 AM #7
Tried sending a p.m. Says your inbox is to full @ this time.
04-13-2018, 06:41 AM #8
emptied it you can send again
04-15-2018, 10:47 AM #9Member
- Jul 2009
- Copiague NY
- 34
Do you still have the 3 liter lower yoke?
04-15-2018, 01:34 PM #10
04-15-2018, 03:50 PM #11Member
- Jul 2009
- Copiague NY
- 34
I am also looking for a swivel pin. You wouldn't happen to have one of those also? How much for the yoke? Th
04-24-2018, 05:06 PM #12Member
- Jul 2009
- Copiague NY
- 34
I found a pin & would like to buy the yoke if you still have it. Where are you located on Great South Bay?
04-24-2018, 08:13 PM #13
Replied
To
PM
Misc parts and 2.0liter Merc parts
By superboattwin250 in forum Misc. Parts and AccessoriesReplies: 1Last Post: 09-09-2015, 02:29 PM
