Results 1 to 3 of 3
Thread: 2.4 200 bleed fitting leaking
03-01-2018, 08:32 AM #1
Hey guys i have a 2.4 200. I have 1 bleed fitting that is leaking where the valve goes in front half. What is best thing to seal it back in with? Thanks
03-01-2018, 09:10 AM #2
Red Loctite
03-01-2018, 10:48 AM #3
Thanks, should had thought bout that
Mercury Tech: Popit valve leaking out of bleed hole
By thinback in forum Technical DiscussionReplies: 5Last Post: 07-21-2017, 09:49 PM -
air horn bleed fitting broken off on merc 280
By davidmercury in forum Technical DiscussionReplies: 9Last Post: 09-04-2012, 06:41 AM -
2L merc running rough, bleed line & oil gear block off leaking?
By gmjim in forum Technical DiscussionReplies: 8Last Post: 09-24-2010, 02:48 AM -
Threaded type bleed fitting
By mach351 in forum Technical DiscussionReplies: 9Last Post: 03-05-2010, 11:18 PM -
Bleed fitting part number?
By Burke Kilgour in forum Technical DiscussionReplies: 14Last Post: 06-15-2003, 11:12 PM
