Results 16 to 20 of 20
Thread: Carb To EFI
03-18-2018, 10:29 AM #166000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
03-21-2018, 05:36 AM #17New Member
- Feb 2017
- sc pa
I used an electromotive ecm with honda cbr throttle bodies and injectors on a old evinrude,very tunable but takes time.
03-23-2018, 07:46 PM #18
Just plugged them all. I didnt have anything welded up.
03-23-2018, 08:35 PM #19
all production blocks have tha bleed valves.. tha efi's have little rubber plugs on 'em... they can be used either way down tha production line......
03-23-2018, 09:12 PM #206000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Try to find some alcohol free 87. The older stuff has trouble with 91 due to low static compression. A lot of Missing coughs and rough running and sputtters when the + cylinders come on is cleared up with lower octane.
Bringing up the compression to run 91 helps a lot. Won’t fix everything.
Another option is checking on starting stuff like a/f and spark.
Mercury Tech: Carb Floats for Mercury 2.4 WH Series Carb
By DirtySouthMikey in forum Technical DiscussionReplies: 0Last Post: 10-24-2012, 03:21 PM -
2 bbl vs. 4 bbl carb???? Automotive vs. Marine carb????
By BBSPURGEON in forum Jet Boats, V-Drives and Stern DrivesReplies: 7Last Post: 05-18-2012, 02:19 PM -
Bought 1997 Merc OS Carb 225 3.0, and parts motor EFI..Can I use efi on carb engine
By Zoomba in forum Technical DiscussionReplies: 2Last Post: 02-19-2012, 08:59 AM
