Results 1 to 11 of 11
Thread: 1992 Fountain Sportfish C/C 31'
02-25-2018, 02:21 PM #1
$49,000
"Sundance"
LOA: 31'
Beam: 8ft 4in
Minimum Draft: 2ft 5in
Dry Weight: 5200lbs
Fuel Tanks: 1 Aluminum (207 Gallons)
(2) 2005 Mercury Verado, 275HP each, 150 hours
This Fountain has low hours, and was recently repowered with twin Mercury Verado 275's. She is a center console with a cutty cabin and head, and has been meticulously maintained and is ready to be on the water. The Fountain is a low center of gravity vessel and performs well fishing or racing to the next place you need to be.
The Fountain has a hand laid composite hull and deck manufactured with multi-directional fiberglass, high density coring, and inter-plastic vinyl ester resin. The hull and deck are laminated, thru-bolted, screwed and sealed together with heavy duty marine sealant/adhesive.
At the stern of "Sundance" is a bench seat that can lay flat for a larger stern area. Right on the transom is a fish hold with a cutting board. Moving forward are two more bench seats, one at the helm and one facing backwards, with a full awning overhead for both. On the port and starboard sides are fishing pole and deck brush holders, along with more pole holders overhead. At the helm, is an older chart plotter and VHF radio with a stereo. At the bow is a cutty cabin with a porta-head. Cushions run overhead as well as below to sleep two. Sundance is a comfortable, fast center console that will do what you need it to, in no time.
Myco Trailer included.
Sundance is currently located in Maine in inside storage but will be moved to Wallingford, CT early spring.
Frank Molé liked this post
02-25-2018, 09:52 PM #2Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7151
- 3 Post(s)
What does this boat run top end and does it cruse at around 4K?
02-25-2018, 09:56 PM #3
Hi Joe,
What exactly are you asking? If it is MPH, the boat will easily do 60mph.
02-25-2018, 10:00 PM #4Supporting Member
- Apr 2003
- 6,644
- 606
- 923
- 1698
- 7151
- 3 Post(s)
So it will cruise at 45 mph without killing it. That is what I was wanting to know.
Please send me some detailed pictures when you have a chance. jperog@hotmail.com I have interest.
02-25-2018, 10:13 PM #5
Hi Joe,
Sent pics.
02-26-2018, 12:05 AM #6Supporting Member
- Apr 2003
- 6,644
- 606
- 923
- 1698
- 7151
- 3 Post(s)
Got them, I will be in touch.
03-23-2018, 02:52 PM #7
**REDUCED** 1992 Fountain Sportfish C/C 31'
Price reduced to $44,000
04-25-2018, 09:46 AM #8
Is your Fountain back in CT I'd like to check it out. I'm in Old Saybrook. LMK thanks
04-25-2018, 04:55 PM #95000 RPM
- Dec 2012
- Detroit
- 212
- 10
Mod deleted
Big and slow
05-19-2018, 04:05 PM #10
New price!!!!
$41,000
05-27-2018, 09:34 AM #11
42 foot Jersey Yacht Sportfish Quality?
By transomstand in forum General Boating DiscussionReplies: 9Last Post: 10-27-2013, 11:40 AM -
Donzi, Proline, Baja, Fountain all being moved to Fountain plant.
By Mr. Demeanor in forum General Boating DiscussionReplies: 9Last Post: 12-14-2010, 12:37 PM -
Opinions on Fountain 25 Sportfish
By blkmtrfan in forum General Boating DiscussionReplies: 9Last Post: 11-22-2008, 08:03 PM -
29 Fountain CC w/225 EFI'S
By jdmek620 in forum Props, Setup, and RiggingReplies: 4Last Post: 09-25-2007, 05:32 AM
