Results 1 to 8 of 8
    Dec 2016
    Florence,ohio
    Left turn outboard lower unit?
    I have purchased my first twin outboard rig. I can not find info on cr lower units. Can someone educate me on what I need and how they work?
    Dec 2016
    Florence,ohio
    I will be using 2.5 225 pro max's
    Dec 2016
    Florence,ohio
    I can't find parts break down , I haven't found a single set of gears or websites to buy parts. I would rather learn to rebuild them than rebuy them.
    Mar 2004
    vonore tn.
    Back in the old days, before C/R l/u,s you could convert std. rotation to left rotation. they were not shiftable but lasted good. cost about $1,000. to convert.
    Dec 2016
    Florence,ohio
    I screwed this post up... I should of asked about 2.5 fishing lowers.. Billybob How do you convert them ?
    May 2015
    Southwest Georgia
    What boat, some people just run two standard rotating lowers. With modern hydraulic steering and some hulls the difference is negligible. I would try it and see before I wen to the expense of rebuilding one.
    Mar 2004
    vonore tn.
    Yes I agree with Fishwhisper. I used to have complete parts list for conversion. I,ll see if I can find it.
  8. Likes Jdomyan liked this post
  9. #8
    Jun 2001
    Cromwell. NEW ZEALAND
    LH rotation gear box uses same gearcase housing but different prop shaft, forward and reverse gears, prop shaft carrier and some bearings
    Popey
  1. Mercury 3.0 left handed lower unit
    By THATGUYJOHN in forum Lower Units
    Last Post: 08-12-2014, 05:45 PM
  2. Mercury Tech: locked in left lower unit
    By enforcer24 in forum Technical Discussion
    Last Post: 03-01-2009, 08:30 AM
  3. left lower unit question???
    By mitchet in forum Technical Discussion
    Last Post: 07-26-2008, 07:19 PM
  4. 99 V6 Merc Lower unit on EBAY 3 hrs left $510.00
    By 4Speed in forum General Boating Discussion
    Last Post: 02-10-2003, 09:04 AM
