Results 1 to 8 of 8
Thread: Left turn outboard lower unit?
02-22-2018, 02:03 PM #1
I have purchased my first twin outboard rig. I can not find info on cr lower units. Can someone educate me on what I need and how they work?
02-22-2018, 07:19 PM #2
I will be using 2.5 225 pro max's
02-22-2018, 11:48 PM #3
I can't find parts break down , I haven't found a single set of gears or websites to buy parts. I would rather learn to rebuild them than rebuy them.
02-23-2018, 09:57 AM #45000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
Back in the old days, before C/R l/u,s you could convert std. rotation to left rotation. they were not shiftable but lasted good. cost about $1,000. to convert.
02-23-2018, 03:54 PM #5
I screwed this post up... I should of asked about 2.5 fishing lowers.. Billybob How do you convert them ?
02-24-2018, 03:47 PM #6Member
- May 2015
- Southwest Georgia
- 96
- 7
- 10
- 19
What boat, some people just run two standard rotating lowers. With modern hydraulic steering and some hulls the difference is negligible. I would try it and see before I wen to the expense of rebuilding one.
02-25-2018, 09:38 AM #75000 RPM
- Mar 2004
- vonore tn.
- 225
- 21
- 28
Yes I agree with Fishwhisper. I used to have complete parts list for conversion. I,ll see if I can find it.
Jdomyan liked this post
02-28-2018, 04:02 PM #8
LH rotation gear box uses same gearcase housing but different prop shaft, forward and reverse gears, prop shaft carrier and some bearings
Popey
Mercury 3.0 left handed lower unit
By THATGUYJOHN in forum Lower UnitsReplies: 0Last Post: 08-12-2014, 05:45 PM -
Mercury Tech: locked in left lower unit
By enforcer24 in forum Technical DiscussionReplies: 5Last Post: 03-01-2009, 08:30 AM -
left lower unit question???
By mitchet in forum Technical DiscussionReplies: 1Last Post: 07-26-2008, 07:19 PM -
99 V6 Merc Lower unit on EBAY 3 hrs left $510.00
By 4Speed in forum General Boating DiscussionReplies: 1Last Post: 02-10-2003, 09:04 AM
