Results 1 to 11 of 11
Thread: Checkmate prop
    Feb 2017
    Wixom lake michigan
    Checkmate prop
    Looking to get a bit more from my current setup, 2012 Checkmate brx 2000/ verado 200 4 cylnder. Runs 64 gps with a stock 25 tempest, about 63 with a 23 tempest. Right around 6400 rpms with each. Little to no chinewalk, and prop to pad doesnt make any huge difference. Feels like the boat isnt lifting enough. Has a 6 inch hyd plate on it now. Should i have one of my props worked for this combo? Also who is the checkmate prop "guru"? I also have a 27 t1 that could be repaired. It is larger in diameter than tbe tempest, maybe with the verados slightly larger gearcase, this would be better? Also tried a 26 ish trophy with very high slip numbers...thanks in advance
    Fwiw i talked to checkmate, they say thier chart says a 25 tempest, buy also said not many of this combo were sold.
    May 2001
    Charlotte, NC
    Ask Wildman.
  3. Thanks JasonRS thanked for this post
    Daytona Fl.
    I have always had the best performance with trophy props. They should not slip much unless you are mounted too high or are over trimmed. Your boat will not chinewalk at those speeds. The trophy will have good bow lift also.
    Check out my new website. (IN PROGRESS) liberatorpowerboats.com
    Things owned. NOTHING!!
    Visit My Liberator and Checkmate Boats Website
    Rent our Log Cabin in Pigeon Forge, TN. http://www.vrbo.com/419205
  5. Thanks JasonRS thanked for this post
    Feb 2017
    Wixom lake michigan
    Good to know, thanks! The trophy i tried was kinda scruffy looking, maybe i need to try a fresher one.
    Anything you reccomend to try and pick up a little speed?
    New Smyrna Beach, FL.
    Quote Originally Posted by JasonRS View Post
    A 300XS would get you almost 30 mph. That is would be the best recommendation I can think of. Nobody sets them up to run better then Randy.
    Daytona Fl.
    Setback makes a big difference. 12" - 16" You can also get a bigger motor!
  9. Thanks JasonRS thanked for this post
    Feb 2017
    Wixom lake michigan
    Wow, 30 mph would be great, but right now an engine isnt in the budget, as bad as i wish it were! Boat is rated for a 250 and i really want to have whipple re flash the vrod to a 225,but im waiting till platinum runs out next year.
    I was wondering about setback, is there anything needed structurally for the hull if i were to add setback to say 12-14"?
    Thanks guys, much appreciated
    Oct 2009
    Gonzales, La
    I think that boat/motor is a pretty cool, reliable, and efficient combo that should break 70 with the right setup. If you don't already have 12" of setback, I'd start there. I don't think the hull has to be modified to do that, but make sure the bolts are sealed up good. For the prop, I couldn't find a faster prop than the Yamaha t1 on my old checkmate pulsare 2100br. I tried a long list of props, including tempest+, txp ot4, txp 3 blade, hydromotive quad 4 xob, high 5, etc and the t1 was the fastest.
  12. Thanks JasonRS thanked for this post
  13. #9
    Feb 2017
    Wixom lake michigan
    Thanks, we kinda thought the same thing, when easy on the throttle, it really sips the fuel. If i can touch 70, i would be super happy! Cmon summer time!!
    Feb 2017
    Wixom lake michigan
    Talked with Checkmate, they said no problem going to 12 inches of setback. Got a bobs bracket on the way!
  15. Likes engineermike liked this post
  16. #11
    North Tonawanda, NY
    My old C-Mate Pulse 210 open bow ran OMC motors and seemed to like the old Raker 1 props. I believe the 1992 vintage hull may have run a slightly narrower pad than the later models- if I recall the pad was 7.5 inch wide. With a 225 Evinrude Vindicator- which I suspect was rated a bit low at 225- and a worked 24 Raker 1 I managed to squeeze out 72-73 mph with a light load. I had sanded the pad a bit at the transom to get a sharper edge than the factory had. I ran with no set-back plate.
    Doug
  1. 15' Checkmate Prop
    By Rocketsled in forum Props, Setup, and Rigging
    Last Post: 05-21-2017, 07:57 AM
  2. Prop for Checkmate 24/225 Pro XS?
    By Looper in forum Props, Setup, and Rigging
    Last Post: 07-06-2009, 11:05 PM
  3. Prop for Checkmate
    By Deet in forum Props, Setup, and Rigging
    Last Post: 05-28-2005, 11:17 AM
  4. 83 checkmate prop help
    By kramerfagan in forum Props, Setup, and Rigging
    Last Post: 08-02-2003, 07:20 PM
  5. Checkmate Prop Selection
    By aaron bjerke in forum Props, Setup, and Rigging
    Last Post: 07-04-2001, 02:32 PM
