Results 1 to 5 of 5
    Dec 2015
    Douglas Lake, Tn
    Water in 3.0 Sportmaster
    My gear oil is a milky white color. I gather it's water in the gearcase. The water never comes out of suspension after being drained and left to sit in the pan. Where are the likely entry points? I thinking driveshaft, propshaft and shift shaft. Is this something I can do at home. I have a Merc gearcase manual but not 100% sure the bearing carrier has to come out to change that seal? Any required tools or parts I would or should need? I'll follow the manual but any good insight is appreciated. Will it kill the gearcase if I run it and change the oil nightly, I want to make the Suwannee river run next month.
    Mar 2004
    vonore tn.
    Milky lube in a sportmaster, is common but it shouldn,t be. the most common leakage point is seal carrier, below impeller plate. The seals there can drop or migrate, & cause leakage. Whenever you fill sportmaster, you must let 1 or 2 oz. of lube drain out to leave room for expansion & contraction. If it still gains water, it must be press. & vac. checked to find leak. The only real fix is to put a reservoir bottle in boat & have a hose run to l/u like Mercruiser.
  3. Likes Capt.Insane-o liked this post
    shift shaft seal and drive shaft seal are common leak spots, Contact Todd at Wicked Powerboats and get his new billet seal holders to help solve this problem JMO
    https://madefi.com/shop?olsFocus=fal...c-2993d4ce101e
  5. Thanks Todd D thanked for this post
    Aylesford Lake,NS Can.
    I agree 100%. I put both of these items in my 3.0L Sportmaster 10+ years ago and I pressure tested it in the fall when I took the motor off the boat and the case held 15psi for two days and no water in the case. I bought two from Todd last year for 2 other gearcases and I am going to order two more sets for another pair of Sportmasters next week.
    Thanks
    Gary
  7. Thanks Todd D thanked for this post
    Likes vnemous liked this post
    Dec 2015
    Douglas Lake, Tn
    Quote Originally Posted by Hydrogasm View Post
    Thanks
    Gary
    Took your advise and installed a set from Todd. Fast shipping, easy install. Went about 100 miles averageing 70ish. Drained it finally yesterday and it was as clean as new lube. River Ranch here I come.
  9. Thanks Todd D thanked for this post
    Likes NICE PAIR, Todd D liked this post
  1. Water in my sportmaster!! Ahhh
    By lafitte2002 in forum Technical Discussion
    Last Post: 01-17-2010, 07:41 PM
  2. Sportmaster water boss
    By Charger70 in forum Technical Discussion
    Last Post: 06-09-2009, 05:50 PM
  3. MORE water psi from the Sportmaster
    By skydog in forum Technical Discussion
    Last Post: 07-18-2006, 03:24 PM
  4. sportmaster water pump
    By maverick1 in forum Technical Discussion
    Last Post: 06-30-2006, 04:05 PM
  5. No water pressure on Sportmaster
    By RedVegas91 in forum Technical Discussion
    Last Post: 06-05-2005, 11:20 PM
