Results 1 to 6 of 6
    May 2001
    Maine
    Hill Buckshot Cleaver
    Anyone ever heard of or tried one of these? Just noticed it on the STV Facebook site.
    Aug 2011
    So.Cal.
    We just started the production version of the buckshot cleaver. First one will ship next week. Happy to answer any questions, lots of testing and development in this prop.
    Attached Thumbnails Attached Thumbnails 77AE1969-EA81-4296-B971-AE6CFB3D3DEE.jpg   1C7E9D85-4D55-4602-B452-B8C6978B7C10.jpg   6212B944-2BA0-42B2-BCDA-2095F89F0CF1.jpg
  3. Likes Mo River Rat, Baker343 liked this post
    May 2001
    Maine
    I believe you mentioned that the 32P Mercury Cleavers have to much rake for the STV. Would this be true if you "hang" one of the newer 3.0L engines on the transom that is about 100 pounds heavier than the 2-4-2.5.s and has a 6k RPM timer.
    Aug 2011
    So.Cal.
    A cleaver is generally a transom lifting propeller. Add rake and the faster you go, the rake tries to let the bow. The higher rake mercury 3-blade cleaver (32 pitch and higher) might work well on an offshore boat or a heavier Euro loaded down with 2-4 people. We went with the slightly lower rake as boats have plenty of lift already. I found the 32 mercury to have too much lift and too much blade for the most but not all STVs. So the heavier motors are different from the 2.5s and changes things. Heavier, so you may want more transom lift, you may want a bigger diameter because the bigger gearcase, more blade and pitch to keep the RPMs under the rev limiter.
    May 2001
    Maine
    What is the rake on the "Buckshot", does it differ in the larger pitch props like the Mercury cleavers? I seem to recall the Mercury 22-30 pitches are 15 degree rake and the 32 and 34 are 20 degree rake.
    Aug 2011
    So.Cal.
    Quote Originally Posted by 4Speed View Post
    We make one-piece moulds and single pours for 14 to 14.5 diameter and 24 to 34 pitch. Rake is about 16 degrees. No hammers or anvils, no weld on blades, tough stainless alloy. Price $550, made to order, race proven. buckshotcleaver@protonmail.com
  1. Ron Hill 32 Cleaver
    By Jgebhardt in forum Propellers
    Last Post: 02-12-2018, 10:10 AM
  2. Ron Hill semi-cleaver on a Voodoo or similar hull?
    By mxz in forum Props, Setup, and Rigging
    Last Post: 01-15-2017, 10:16 AM
  3. Ron Hill 32 Cleaver
    By josh7_78 in forum Propellers
    Last Post: 02-08-2016, 01:39 PM
  4. ron hill cleaver
    By xskid1 in forum Propellers
    Last Post: 01-06-2015, 04:45 PM
  5. Ron Hill semi-cleaver (not about outboard and racing history)
    By Markus in forum Outboard and Racing History
    Last Post: 01-11-2003, 10:58 AM
