Page 9 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 121 to 135 of 275
  1. #121
    Could always try a warm weak acid bath 5 pH to try dissolving the mineralization. Carbonic or citric acid, changing it occasionally to maintain the pH range.
  2. Thanks Glastron1987 thanked for this post
    Likes nitro_rat, Glastron1987 liked this post
  3. #122
    Plainville, CT
    Last couple of previous posts not my choice of words, but does express my feelings accurately.
  4. #123
    Apr 2017
    pa
    5 Post(s)
    I've had to this more than once. Salt motors suck!! I don't even bother trying to separate anymore until I take a 4 1/2 grinder with a good zipwheel and cut the four longer bolts through the upper exhaust plate. exhaust plates are easily replaced.
  5. Likes Onetime, nitro_rat liked this post
  6. #124
    Plainville, CT
    So if there is a next time on this, I'll head for the cutting much sooner.
    This weekend I'm hoping to get to this. What I'm thinking is that if I use a drill instead of the cutter, the plate should be quite reusable. Any drawback to that?
  7. #125
    Apr 2017
    pa
    5 Post(s)
    What are you going to drill?
  8. Likes nitro_rat liked this post
  9. #126
    Plainville, CT
    Apr 2017
    pa
    5 Post(s)
    I was just trying to save you time and aggravation. I can do it in 15 minutes. I never had much luck drilling stainless surrounded by aluminum with a round surface. Usually walks and wollers.
  11. Likes nitro_rat liked this post
  12. #128
    Plainville, CT
    Maybe I'll try one with the drill and see how it goes, but I am in the mood for something easy.
  13. #129
    Nov 2016
    Missouri
    A machinist carbide centering drill bit would be great to use first and then a small drill bit for the pilot hole then increase your sizes as you go, maybe you would have more of a chance getting in the center of bolt.
  14. #130
    Plainville, CT
    Drilling even with normal bits actually wasn't too bad. Took me about 2.5 hours for all 4. Started with smaller bits and worked up to my largest 1/2", cleaning the chips away and oiling regularly. If the suds are stainless, they didn't seem too difficult to get though.
    However, there are two issues: 1) getting the hole centered on the stud was very difficult to judge with the irregular shape of the plates, and 2) judging when to stop drilling in order to save the plate was also quite difficult.
    Maybe from the photos you can see that I missed center on probably all four studs, as there is still some stud left on each. Also, I probably drilled all the way through 3 out for 4 holes, so I assume the plate is no longer usable at this point.
    So as most of you advised, I’ll be grinding next (which should have been first).
ID:	408026Click image for larger version.
ID:	408027Click image for larger version.
ID:	408028Click image for larger version.
  15. #131
    Apr 2017
    pa
    5 Post(s)
    Well, atleast you have it separated
  16. #132
    Plainville, CT
    Actually the photos may not be great, but there was no separation or budging of any sort after drilling. So I finally did attempt to use the pneumatic 3" die grinder. That was even too weak to cut adequately. Thinking of “Tool Expectation #5” I finally resorted to my 7” industrial angle grinder with a cutoff. That did it… easily, in minutes!
ID:	408055Click image for larger version.
ID:	408056Click image for larger version.
  17. Likes Bruce2, Merc 2.5, nitro_rat liked this post
  18. #133
    Apr 2017
    pa
    5 Post(s)
    That’s the ticket!!
  19. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  20. #134
    Plainville, CT
    Any tricks on getting the remaining stud stumps out of the block. Or should just some vice grips do it? Some came out by hand. I'm a little concerned about those tenacious ones.
  21. #135
    Apr 2017
    pa
    5 Post(s)
    Usually aren't too bad, but...... Start with vice grips or good little pipe wrench. might have to put flat spots on them with a grinder to get better grip.
  22. Thanks Glastron1987 thanked for this post
  1. 1994 Mercury 2.5 260 Rebuild
    By Rock Steady in forum Technical Discussion
    Last Post: 07-30-2022, 06:03 PM
  2. 1994 Mercury Pro Max rigging
    By Warrenroadie in forum Technical Discussion
    Last Post: 02-17-2017, 04:01 AM
  3. Mercury Tech: 1994 2.5 200HP Mercury EFI XR
    By FL_Sanger_Barefooter in forum Technical Discussion
    Last Post: 06-26-2016, 08:20 AM
  4. Mercury Tech: 1994 Mercury 175 2.5 oil conversion
    By Liberator225 in forum Technical Discussion
    Last Post: 04-23-2012, 07:10 AM
  5. Need Some info on 1994 Mercury 200 xri
    By cheapbeater in forum Technical Discussion
    Last Post: 04-16-2009, 10:20 AM
