Page 8 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 106 to 120 of 275
  1. #106
    Plainville, CT
    Thanks for all of the good ideas. For now I did get the motor upside down without killing myself (so far). Will give the PB-Blaster a try over the next week. Just as a note, before getting to this I had pried the heck out of both the two front and two rear studs with bars, without a budge, but did not try the "back-down the nuts" method. That may be worth a try.
  2. #107
    Jan 2010
    Rotorua, NZ
    I had to remove my powerhead from the mid a couple years back, pretty sure it had been on there since '87, probably in salt and all. I got lots of suggestions from people in here but the only thing that did it was this exact process (would love to buy a beer for whoever explained this to me!):
    The 4 longest studs were the main problem for memory, but I did this to all but the shortest (2-3")studs
    You can use the 2 short rear studs to wind a nut down onto a couple of sockets or similar to pry the PH upwards (easier to really load it up this way than by lifting the motor). Keep these loaded/tensioned up so the powerhead lifts when you finally get it un-stuck.
    Hold the gas torch on the end of the stud for about 10 minutes, aim to get the stud as hot as hell, to help dry the seize out, then hit the end of the stud with the air chisel with a V shaped chisel on it, so it's easy to hold pressure on the stud without slipping off (you'll destroy the threads obviously). Hold the chisel on the threads/stud for literally 20 minutes or so, if you got enough heat in the stud you should eventually see what looks like smoke start to pour out of the stud hole. It's the calcification turning to dust due to the heat and vibration. After a while you'll see a gap forming around the stud if you look up it. The longer the stud, the more heat and air chiseling it'll need. Repeat heat/chisel/heat/chisel on each stud till the smoke/dust stops.
    Eventually when you've been doing this for hours it should come free, but if it's anything like mine, expect to be there a long time. I don't imagine any amount of penetrating oil/anti-seize would have done it. There is a lot of material sticking those long studs in place.
    I can't stress enough how time consuming and boring this process was, but it worked! And s**t I was grateful for having it explained to me! Hope it helps
  3. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  4. #108
    Plainville, CT
    What kind of torch did you use for that.. propane, map, oxy-acetylene? The best I could do with only the propane was to get the studs to about 400 degrees. I think because of how the heat dissipates. Haven't tried anything hotter yet though.
  5. #109
    Jan 2010
    Rotorua, NZ
    Yeah I just have a little bottle torch like this - did the trick tho
  6. Thanks Glastron1987 thanked for this post
  7. #110
    Plainville, CT
    On day 5 with it hanging upside down. 1-2 times per day I've been applying PB-Blaster, and the air hammer. Also, I did get wedging in the two back studs using the nuts and spacers. Nothing moved yet.
    I'll give it a few more days like that, then probably will combine the heat and air hammer.
  8. #111
    Drink a dozen beer and give her a hug
  9. Thanks dompie99 thanked for this post
    Likes dompie99 liked this post
  10. #112
    Plainville, CT
    It’s been upside down now for over a week. Just about every day I’ve applied PB-Blaster and used the air hammer on and around the two long studs. Also, I’ve applied heat from an oxy-acetylene torch. Still have the two nuts in back wedged with tension and pried with a wrecking bar in front.
    Nothing seems to have budged even a little bit. The only thing I’ve noticed is that when I hammer around the studs at the mid-section level, the sound has changed to a much higher pitch which hurts my ears. I think that may mean that the mid-section may be more free than it was. Unfortunately, both top and bottom plates need to free up as well.
    What I may try next is putting it back right-side-up, heating it again, then hammering it again, with a bigger compressor. The 3 gallon pancake doesn’t hold much air for the hammer. That may be my last step before cutting into the plate(s).
  11. #113
    Plainville, CT
    Found a way to hang the motor upside down on the lift and force some tension from beneath by using a bar attached from underneath. Think this is how someone pulled the studs right out of the powerhead, so I won’t go too crazy with the tension.
    … and now I have a big air compressor so can use the air hammer much more continuously. Also, I heated the long studs with the oxy-acetylene torch until they were red/orange a few times.
    After the first session with the better air, plenty of PB-Blaster and the new tension, there is still no sign of budging.
    After a couple more session like this spread over the next few days with no budging and the drill is coming out.
ID:	407218Click image for larger version.
ID:	407219Click image for larger version.
  12. #114
    Jan 2010
    Rotorua, NZ
    I think the pb blaster is a bad idea. You’re trying to dry the studs out so the corrosion/calcification can turn to dust and come out - don’t think the pb blaster will be helping that
  13. #115
    Jul 2012
    Lufkin, Texas
    Have you considered purchasing another motor from a freshwater area? Around here V6 Mercs come up for giveaway prices occasionally. I’m getting worried that you’re expending too much of your life essence on this project!
    Whip out the death wheel already and chop it into submission!!!
    Josh Peterson
  14. Likes Onetime, W2F a V-King liked this post
  15. #116
    Plainville, CT
    You're right. I'm ready to cut. I was going to use a drill, but is there a better tool to use?
  16. #117
    Nov 2016
    Missouri
    Die grinder with a cut off wheel on it..
  17. Thanks Glastron1987 thanked for this post
  18. #118
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by Bruce2 View Post
    Yep, that’s the DEATHWHEEL!!!
    Josh Peterson
  19. Thanks Glastron1987 thanked for this post
  20. #119
    Jul 2012
    Lufkin, Texas
ID:	407572Click image for larger version.
    Josh Peterson
  21. Thanks Glastron1987 thanked for this post
    Likes gmacrae, Glastron1987 liked this post
  22. #120
    Pekin, IL
    Looks to be pretty accurate.
    Rock
    Team Junk
  23. Thanks Glastron1987 thanked for this post
  1. 1994 Mercury 2.5 260 Rebuild
    By Rock Steady in forum Technical Discussion
    Last Post: 07-30-2022, 06:03 PM
  2. 1994 Mercury Pro Max rigging
    By Warrenroadie in forum Technical Discussion
    Last Post: 02-17-2017, 04:01 AM
  3. Mercury Tech: 1994 2.5 200HP Mercury EFI XR
    By FL_Sanger_Barefooter in forum Technical Discussion
    Last Post: 06-26-2016, 08:20 AM
  4. Mercury Tech: 1994 Mercury 175 2.5 oil conversion
    By Liberator225 in forum Technical Discussion
    Last Post: 04-23-2012, 07:10 AM
  5. Need Some info on 1994 Mercury 200 xri
    By cheapbeater in forum Technical Discussion
    Last Post: 04-16-2009, 10:20 AM
