Results 76 to 90 of 275
Thread: Mercury 1994 2.0L 150
04-14-2018, 07:37 AM #765000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
04-15-2018, 02:52 PM #775000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Well, separating the powerhead from the midsection is turning out to be difficult. I sprayed PB blaster everywhere and applied the heat gun to each of the 10 stud areas, raised the hoist so that the motor stand was just off the floor, then pried at the studs (with the nuts) pictured below, and the two rear ones not pictured, on both sides. Nothing seemed to hint at any separation occurring. Is it usually those 4 longer studs that cause the issues? Maybe I should try a torch on those 4?
04-15-2018, 05:22 PM #78
You need to take those 2 nuts off the studs back of the motor or powerhead will not come off..the nuts under the heads...if im seeing that picture right.
04-15-2018, 05:31 PM #795000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
They are loose enough so the powerhead should at least budge, I left them on for prying so the threads do not get ruined.
04-15-2018, 06:40 PM #80Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
If it is the longer studs holding you up???
The Best tip I ever got on this was to use an air chisel(gently with control) with a blunt round bit to impact on the bottom of the studs. The impacting breaks the corrosion free. Even better if you happen to have a rivet gun. Looks just like the air chisel but has much more control.
Never had much luck with heat.
Glastron1987 thanked for this postGlastron1987 liked this post
04-15-2018, 09:26 PM #815000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
I see how an air chisel may work, but not clear how a riveter would. Of course I have neither, but I do have a couple of nailers. How would that work?
04-15-2018, 10:33 PM #82Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Might as well drop the lu if you haven't. Give the ph some hard kicks to the top sides with the bottom of your boot.
04-16-2018, 07:48 AM #83Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
Don’t see how a nailer could work.
The rivet gun I’m referring to is for bucking rivets, not a pop rivet type riveter.
Can get a cheap air chisel at Harbor Freight, won’t have good control with the trigger though so be careful. The trigger is more like an on/off switch.
Rivet gun will cost quite a bit more, they have excellent control. Their trigger is designed to have control and can regulate the hits it gives by the feed of the trigger.
04-16-2018, 07:50 AM #84Scream And Fly VIP
- Jul 2013
- California
- 1,555
- 21
- 63
- 83
- 294
04-16-2018, 09:52 AM #85Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
First a splash of High Karate then tunes, Everybody was Kung Fu Fighting!
04-16-2018, 10:43 AM #86
Go get 2 thin nuts to fit the studs thread them on the studs and jam the two nuts together and try to break the stud lose to remove it..just an idea.
04-16-2018, 07:40 PM #875000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Thanks for the tips. My karate is rustier that the studs. Also, not sure how two nuts will work. I'll plan on picking up an air chisel and see how that works.
04-16-2018, 07:50 PM #88Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Guess you' have it on a stand. If you could keep it from tipping , bolt it to the floor, and shake the crap out of it by grabbing the top of the ph till it breaks. Could always put it all back together and take it for a 5 min ride in a chop with the nuts loose.
04-19-2018, 09:51 AM #895000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Just ordered a used mid-section, long versus the x-long that the powerhead is on now. The number listed for my motor in the long is 8343A10. I ordered an 8343T10. Did I mess up and will have compatibility problems?
04-21-2018, 02:19 PM #905000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Tried impact hammer to the studs, and a (small) sledge hammer and block to the bottom midsection, and some more weight on the stand with the hoist above. No luck separating the powerhead from the midsection yet.
1994 Mercury 2.5 260 Rebuild
By Rock Steady in forum Technical DiscussionReplies: 19Last Post: 07-30-2022, 06:03 PM -
1994 Mercury Pro Max rigging
By Warrenroadie in forum Technical DiscussionReplies: 32Last Post: 02-17-2017, 04:01 AM -
Mercury Tech: 1994 2.5 200HP Mercury EFI XR
By FL_Sanger_Barefooter in forum Technical DiscussionReplies: 7Last Post: 06-26-2016, 08:20 AM -
Mercury Tech: 1994 Mercury 175 2.5 oil conversion
By Liberator225 in forum Technical DiscussionReplies: 2Last Post: 04-23-2012, 07:10 AM -
Need Some info on 1994 Mercury 200 xri
By cheapbeater in forum Technical DiscussionReplies: 3Last Post: 04-16-2009, 10:20 AM
