Page 5 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 61 to 75 of 275
  1. #61
    TX......somewhere?
    part no.
    91-77109A 3
    ya, more than likely, gonna need it again...................
  2. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  3. #62
    Looks like a good luck marine piston.
  4. Likes nitro_rat liked this post
  5. #63
    Plainville, CT
    Great to get the tool number if I do end up doing more than this one piston. I did end up finding a youtube video that showed a technique that was easy enough for me to follow. You put one end a ways past the notch, so that the other end just passes the notch. Hold the whole thing down while placing a small screwdriver in the notch and pry it towards the center from the top. That was a lot easier than the two other techniques I saw people use.
    As for the piston, I have confidence it will work for me, but I would expect a dealer would have used a full replacement part.
  6. #64
    Plainville, CT
    Got #3 piston back in with new rings. I did reuse the cap bolts with a drop of red #271 loctite. If not for the extra shipping cost on two bolts I (ideally) would have used new ones but since others have had good luck reusing them I have high confidence it will hold together. They torqued nicely, incrementally, to 30 ft/lbs. I was surprised how well it all went back together, and a long pair of needle-nose pliers helped a lot getting the lower rod bearings in place. One thing I did not like is that with the intake still on, I could pencil check the cap mating pretty well on one side, but not on the other. I’ll double check that later when I pull more apart for de-rusting. It does seem to spin well though. Next step will be to put the head back on. Can’t wait to try that compression test again.
  7. #65
    Plainville, CT
    #3 compression looks solid now, right with the others!
  8. #66
    Plainville, CT
    So now I've got the 10 powerhead nuts and bolts off. If I just lift with a hoist should the engine along with the exhaust plate easily come off or should I expect to have to rap it and heat it up? Any tricks that will help?
  9. #67
    Pekin, IL
    Should be 10 nuts, no bolts. Powerhead will lift off but you will need to remove 5 bolts and motor mounts( 2 more nuts and bolts ) to remove adapter unless you are on a 1 pc plate. If motor has been in salt you may need explosives. When I get one that wants to stick I pry on one of the two front studs and/or rear 4 studs being very careful not to damage threads. Put a little load on lift ring while prying.
    Rock
    Team Junk
  10. Thanks Glastron1987 thanked for this post
  11. #68
    Plainville, CT
    Oh yes, I rechecked, it was 10 nuts. So would plate come off after motor is lifted off or before? I'm thinking lifting off motor first then worry about the plate.
  12. #69
    Jul 2012
    Lufkin, Texas
    Plate comes off after powerhead
    Josh Peterson
  13. #70
    TX......somewhere?
    be sure to take tha shift shaft loose at tha anchor bracket.. my achilles heel!
  14. Thanks Glastron1987 thanked for this post
  15. #71
    Pekin, IL
    I am glad I am not the only one.
    Rock
    Team Junk
  16. Thanks Glastron1987 thanked for this post
  17. #72
    Plainville, CT
    It looks like there is a pin that needs to be driven out through the shift arm that is very difficult to get at. Does that sound right?
  18. #73
    TX......somewhere?
    no...
    7/16's nut/glide block on anchor bracket......
  19. Thanks Glastron1987 thanked for this post
  20. #74
    Aug 2015
    NE Tennessee
    The short stud sticking up is where the shift cable attaches to it. That's the 7/16 nut he is referencing to. Just take the nut off and it will stay with the mid section when you pull the power head.
  21. Thanks Glastron1987 thanked for this post
  22. #75
    Plainville, CT
    When stripping the motor down I think I did remove that, but will double check.
  1. 1994 Mercury 2.5 260 Rebuild
    By Rock Steady in forum Technical Discussion
    Last Post: 07-30-2022, 06:03 PM
  2. 1994 Mercury Pro Max rigging
    By Warrenroadie in forum Technical Discussion
    Last Post: 02-17-2017, 04:01 AM
  3. Mercury Tech: 1994 2.5 200HP Mercury EFI XR
    By FL_Sanger_Barefooter in forum Technical Discussion
    Last Post: 06-26-2016, 08:20 AM
  4. Mercury Tech: 1994 Mercury 175 2.5 oil conversion
    By Liberator225 in forum Technical Discussion
    Last Post: 04-23-2012, 07:10 AM
  5. Need Some info on 1994 Mercury 200 xri
    By cheapbeater in forum Technical Discussion
    Last Post: 04-16-2009, 10:20 AM
