Page 4 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 46 to 60 of 275
  1. #46
    Jan 2018
    Alabama
    Yes on the bolts - I do reuse them. I apply 1 drop of Red Loctite to the threads of the rod/cap bolts and follow the torque steps mentioned after being absolutely sure the caps are aligned. A word of caution, I pulled/destroyed all of the threads out of a motorcycle engine's right case and then my jetski pump by using Red in aluminum threaded holes. Only use Red when it steel to steel and you don't plan to take it apart any time soon. Keep it away from soft aluminum - it is tougher than the threads are and your bolts will have a layer of aluminum when you try to remove them. I learned what and how to use Timeserts to fix my mess.
  2. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  3. #47
    Aug 2015
    NE Tennessee
    Some heat applied to "dreaded red" will allow removal of fastener without thread damage.
  4. Thanks Glastron1987 thanked for this post
    Likes tlwjkw, Glastron1987 liked this post
  5. #48
    May 2014
    Livingston, Louisiana
    Technically speaking, not supposed to reuse bolts, because they are a torque to yield design. Buuut, you won't have any problems reusing them from my experience in a stock application. If hot roddin go to SPS or ARP non torque to yield type bolts. When reusing them torque them at 30 ft/lb and that's it, no additional rotations. If you use new bolts, then do the additional rotation as described in manual. Reason being, the bolts have already been tightened beyond there elastic stage near their yield point once and likely will not be able to take that additional rotation again before giving up the ghost.
  6. Thanks Glastron1987 thanked for this post
  7. #49
    Plainville, CT
    Thanks... Think I got it:
    1) Use a drop of red locktite
    2) Make sure the cap is aligned
    3) Torque in increments (e.g. start with around 10 ft/lbs)
    4) Final torque to 30 ft/lbs (if reusing the bolts)
    5) NO final 90 degree twist (if reusing the bolts)
  8. Likes FORBESAUTO liked this post
  9. #50
    Pekin, IL
    There are two red Loctites. 262, permanent, and 271, high strength. Use the 271.
    Rock
    Team Junk
  10. Thanks Glastron1987 thanked for this post
  11. #51
    Rod bolts are like $2.00 a piece. Don't reuse them.
  12. Thanks Glastron1987 thanked for this post
  13. #52
    Jan 2018
    Alabama
    Uhhh, $5.80, but who's counting?
  14. Thanks Glastron1987 thanked for this post
  15. #53
    Plainville, CT
    Took out wrist pin of #3 piston to put in a new piston kit. I count 29 needs bearing. I don't think I dropped any. Is that the correct number?
  16. #54
    May 2014
    Yep 29. Shouldn't have any room to put another in rod when all in place, should fill all the space up.
  17. Thanks Glastron1987 thanked for this post
  18. #55
    Plainville, CT
    Just noticed that the new piston pin is a bit tight in the new piston. I can get it in by rapping it, but that won't work when trying to put the needle bearings in. Should I loosen it up with emery cloth or by just working the pin back and forth and turning it inside the piston? There are no obvious bad edges.
  19. #56
    Jul 2012
    Lufkin, Texas
    Try putting the pin in the freezer. It will shrink and it should slide right in...
    Josh Peterson
  20. Thanks Glastron1987 thanked for this post
  21. #57
    Plainville, CT
    Good idea, didn't think of that. So I tried it; it helped a little but still too tight as I'll still have to rap it to get it in and am concerned about needle bearings going all over the place.
  22. #58
    May 2014
    Sumpin ain't right. Got a bur, been dropped on its head, machined cross-eyed or sumpin. Generally new piston and pins will easily glide in, kinda normal for used ones due to build up that would have to be cleaned and dressed up to move freely again.
  23. #59
    Jul 2012
    Lufkin, Texas
    Sumpin ain't right.
    Yep. May need to contact vendor and get a replacement!
    Josh Peterson
  24. Thanks Glastron1987 thanked for this post
  25. #60
    Plainville, CT
    It probably does make sense to go back to the vendor on this, although thought I’d give this a shot: some 1500 grit then 2000 grit paper inside the hole. Then washed it out good with soap and water and then gave it a dousing of WD40. It seemed to work OK.
    Got the (29) needle bearings back in place now. Used the grease method (i.e. using Lubriplate #105 Motor Assembly Grease). I might have tried the dry method, but I don’t have a spacer or a lathe/machine to cut one from the old pin in order to attempt it. The grease seemed to work fine, although I can’t say that this was one of my favorite things to do, thinking I might forget or lose one of those tiny needles with my clumsy fingers. Probably 30 years ago my fingers were not so clumsy.
    Now for the wrist pin retainers. I shot one somewhere on my back patio. If not for the leaves and other yard debris around I might have had a chance to find it. Guess I’ll have to use an old one. Also, I wonder if there is a good tool to help with these clips. To me it seems hopeless using a screwdriver without scarfing up the piston or my fingers.
  1. 1994 Mercury 2.5 260 Rebuild
    By Rock Steady in forum Technical Discussion
    Last Post: 07-30-2022, 06:03 PM
  2. 1994 Mercury Pro Max rigging
    By Warrenroadie in forum Technical Discussion
    Last Post: 02-17-2017, 04:01 AM
  3. Mercury Tech: 1994 2.5 200HP Mercury EFI XR
    By FL_Sanger_Barefooter in forum Technical Discussion
    Last Post: 06-26-2016, 08:20 AM
  4. Mercury Tech: 1994 Mercury 175 2.5 oil conversion
    By Liberator225 in forum Technical Discussion
    Last Post: 04-23-2012, 07:10 AM
  5. Need Some info on 1994 Mercury 200 xri
    By cheapbeater in forum Technical Discussion
    Last Post: 04-16-2009, 10:20 AM
