Page 17 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 241 to 255 of 275
  1. #241
    Nov 2016
    Snohomish, WA
    Quote Originally Posted by Glastron1987 View Post
    ...and here it is after 4 coats of color and 4 coats of clear.
    Attachment 415710
    Wow, that’s a lot of painting. What kind did you use?
  2. #242
    Plainville, CT
    From what I've read, automotive paint is really better quality, but for this I took a chance and went on the cheap... Moeller spray cans... about $9 per can. It's lacquer based, and dries fast. As long as you don't wait too long between coats no sanding is required. It smells really bad, so I figured it might hold up.
  3. #243
    Nov 2016
    Missouri
    Nice Job!!
    Daddy taught me to never force anything but to just get a bigger hammer.
    1995 19'0" Champion bass boat
    1995 200 XRI
  4. #244
    Plainville, CT
    After trying to consider all of the particulars of my situation (e.g. price, lack of a lathe, reliability, vibration, vibration avoidance, wear, safety, performance, etc.), I finally decided to go with a full set of bobsmachine solid mounts. So if anyone needs a pair of unused OEM uppers, let me know ($120/includes shipping).
  5. Likes Bruce2 liked this post
  6. #245
    Jun 2009
    Bristol, Connecticut
    BUMP Any updates?
  7. #246
    Plainville, CT
    Had some distractions the last few months, but had a chance to do some more work the last few days... attaching the mid-section to the swivel (connecting the motor mounts). Aside from the missing washers, can anyone confirm which upper mount is in correctly? I think the one on the left (or bottom) is with the long part towards the inside, but its been a while since taking it apart so I'm forgetting.
Name:	IMG_1540 UpperMounts.jpg
  8. #247
    Plainville, CT
    Can anyone tell me if these upper mounts were installed correctly (i.e. long side inward)?
    Also, does that leather bumper between the steering arm and housing assembly really do anything? I already torqued the bolts and forget to put that in between.
  9. #248
    Jul 2012
    Lufkin, Texas
    That looks good. Long side in is correct. The bumper is listed as “use where applicable” in the parts book. Not too big a deal to put it in since you have it though...
    Josh Peterson
  10. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  11. #249
    Sep 2017
    Ashland city tn
    So how far out are you from firing her up?
  12. #250
    Plainville, CT
    Quote Originally Posted by Merc 2.5 View Post
    Too far out. All I can say is that I'm heading in the right direction. My guess is next summer I'll be in shape to attempt to fire. Hoping to get the power head mounted before Thanksgiving. I think I'm close to that.
  13. #251
    Plainville, CT
    Any gasket sealant or anything else (besides new gaskets) like that recommended between the top and bottom plates, or between the power head and top plate?
  14. #252
    Sep 2017
    Ashland city tn
    I just did mine dry but had a fresh cut on everything. If you clean it good dry should b fine, dont really wanna take a chance of getting sumthin stuck in water passage of the plate imo
  15. Thanks Glastron1987 thanked for this post
  16. #253
    Plainville, CT
    Great thanks. I didn't really want to add anything unless there was a good reason.
  17. #254
    Plainville, CT
    Does this gasket look right? The medium sized holes just around the inside perimeter don't directly line up to anything.
  18. #255
    Plainville, CT
    So now what concerns me a little more is that the old bottom plate from the 25" mid is a little different than the one that came with my replacement 20" mid. Anybody know the difference and is the replacement one OK to use?
ID:	421896Click image for larger version.
  1. 1994 Mercury 2.5 260 Rebuild
    By Rock Steady in forum Technical Discussion
    Last Post: 07-30-2022, 06:03 PM
  2. 1994 Mercury Pro Max rigging
    By Warrenroadie in forum Technical Discussion
    Last Post: 02-17-2017, 04:01 AM
  3. Mercury Tech: 1994 2.5 200HP Mercury EFI XR
    By FL_Sanger_Barefooter in forum Technical Discussion
    Last Post: 06-26-2016, 08:20 AM
  4. Mercury Tech: 1994 Mercury 175 2.5 oil conversion
    By Liberator225 in forum Technical Discussion
    Last Post: 04-23-2012, 07:10 AM
  5. Need Some info on 1994 Mercury 200 xri
    By cheapbeater in forum Technical Discussion
    Last Post: 04-16-2009, 10:20 AM
