Results 226 to 240 of 275
Thread: Mercury 1994 2.0L 150
07-25-2018, 06:16 AM #2265000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
07-25-2018, 09:39 AM #2275000 RPM
- Nov 2016
- Snohomish, WA
- 203
- 15
- 9
- 16
Sorry, a little confusion in terminology there. I meant the yoke as the aluminum part I was referring to as the swivel. Like Bruce2 and FORBES were saying there, I still some slop in mine with a new to me used, but visually unworn yoke and brand new steering tube. It wasn’t much, but I could “jiggle” it a small amount. After I was able to use a shop press to get the cut stub out of the yoke, the old corroded part had noticeably more play than the replacement one.
Glastron1987 thanked for this postGlastron1987 liked this post
07-30-2018, 09:14 PM #2285000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
08-05-2018, 05:30 PM #2295000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
nitro_rat liked this post
08-07-2018, 09:16 PM #2305000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Got my quote today for a small local shop toturn some mounts out of delrin... $100 each. So not a good option for me. Stillneed to paint the replacement mid-section but as soon as that’s done it should beready to mount. Thinking about it, I am wondering what the loaddistribution is on the upper versus lower mounts. I was thinking that when thelower ones are loose it would cause more steering problems because they arecloser to the skeg which controls direction. Although I hear more complaints aboutthe upper ones needing replace because of looseness.
08-07-2018, 09:32 PM #2315000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
08-07-2018, 10:02 PM #232
08-07-2018, 10:19 PM #233
08-08-2018, 06:40 AM #2345000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
It's a 1986 Glastron CVX-17. It's a 17'7" boat weighing about 875lbs w/o motor. I believe there is somewhat of a pad towards the back bottom. Its rated for 140hp. This is a 150 I'm reassembling. When complete, the motor should be pretty stock except probably for some composite reeds, and maybe some stuffers. It runs now in the 40-45mph range with a 1984 Mariner 75hp (2/3's of tower-of-power). So my guess is that it will do no more than about 65mph when complete. Although 45 seems pretty fast being so close to the water, it also seems the boat could handle some more speed, but I want to be safe about it.
08-08-2018, 06:49 AM #2355000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Actaully that was not speced out in the quote, but that is a good question. I will try to find out. They did say that the UV resistent material was very expensive compared to the Acetal and Delrin black and white, which were about the same. This was a quote just for the lower ones for now. Also, I had assumed starting with 2" stock thinking that the middle section would not require any machining. One other thing is that quantity would drive price down significantly, but not sure of what that volume is.
Also I am realizing that even at $100 it is not much different in price than the OEMs. Seems the best bargain by far is to go with the aluminum.
08-08-2018, 07:08 AM #236
08-08-2018, 08:33 AM #237
Setup is where the main cost is at in a machine shop. On the 2 inch white alls we had to do was turn the diameter of the ends to fit for the lowers. The uppers i had a smaller diameter piece i had bought and still had to turn them down. I had to buy 2 foot pieces of both material when i bought the stuff so i have plenty of delrin left over...lol
Daddy taught me to never force anything but to just get a bigger hammer.
1995 19'0" Champion bass boat
1995 200 XRI
08-09-2018, 04:58 PM #2385000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Bruce2 liked this post
08-15-2018, 08:32 PM #2395000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Started to paint the 20" mid-section today after prep yesterday. First picture is just as the etch primer is being applied, then a picture with 3-4 coats complete... roughly one spray can. If the paint is as durable as the smell is strong, it should hold up great. Hopefully will apply 3 or so coats of black tomorrow.
08-17-2018, 07:09 AM #2405000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
Merc 2.5 liked this post
1994 Mercury 2.5 260 Rebuild
By Rock Steady in forum Technical DiscussionReplies: 19Last Post: 07-30-2022, 06:03 PM -
1994 Mercury Pro Max rigging
By Warrenroadie in forum Technical DiscussionReplies: 32Last Post: 02-17-2017, 04:01 AM -
Mercury Tech: 1994 2.5 200HP Mercury EFI XR
By FL_Sanger_Barefooter in forum Technical DiscussionReplies: 7Last Post: 06-26-2016, 08:20 AM -
Mercury Tech: 1994 Mercury 175 2.5 oil conversion
By Liberator225 in forum Technical DiscussionReplies: 2Last Post: 04-23-2012, 07:10 AM -
Need Some info on 1994 Mercury 200 xri
By cheapbeater in forum Technical DiscussionReplies: 3Last Post: 04-16-2009, 10:20 AM
