Page 14 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 196 to 210 of 275
  1. #196
    Plainville, CT
    Very puzzling. I will see what happens as more of the whole thing is assembled. Thanks for the comments.
  2. #197
    Jul 2013
    Quote Originally Posted by Glastron1987 View Post
    This is the new power trim unit. It’s from a 1997 so it’s a 2-wire instead of the three wire. It took me a while to figure out (from posts) that the polarity of the two wires are just switched for changing the direction up or down. This just didn’t seem right (or intuitive) to not have a fixed ground, but it actually makes testing a bit more convenient. Guess I’ll have to get a harness with the relays instead of using the solenoids that came with the motor.
    Attachment 411688
    Have the harness and switch assembly that’s for a two wire pump. $35.00 shipped
ID:	411740 Click image for larger version.
  3. Thanks Glastron1987 thanked for this post
  4. #198
    Plainville, CT
    Quote Originally Posted by Onetime View Post
    Thanks. I'm holding off on this until more of the whole thing is back together.
  5. #199
    Plainville, CT
    As expected with this engine, the screw heads for retaining the trim sensor in the swivel bracket broke off when attempting to remove them. So the threads had to be restored. The attached E-ZLocks were used. Had to drill out an oversized hole and tap them, but it worked out with a relatively low level of pain with the bracket completely removed. The locking material on them was a bit dry so I added in some red Loctite as well. Attached is after paint touch-up. Ready to install swivel bracket now.
ID:	411966Click image for larger version.
  6. #200
    Plainville, CT
    The trim, including the small rams, goes all the way down once the swivel bracket has been installed.
  7. Likes Capnmoench liked this post
  8. #201
    Nov 2016
    Snohomish, WA
    You had better luck with your trim sender screws than me. I extracted them and tried to use a tap to clean the threads on one. Tap broke. Long story short: Ended up with a 3/8” frozen aluminum rod and jammed it into the torch heated hole. Ground it flush, drilled, tapped, painted.
  9. Thanks Glastron1987 thanked for this post
    Likes Glastron1987 liked this post
  10. #202
    Plainville, CT
    Porta Products out of Florida for the mounts.
    http://www.portaproducts.com/index.p...e=motor-mounts
    I contacted portaproducts about their composite mounts. They said they no longer sell them, but referred me to a number at Sierra. I contacted Sierra, and the technical rep knew nothing about composite mounts, just the normal rubber/metal ones.
    Since I don’t have a lathe to turn some delrin ones, it looking like some solid ones will likely be the solution.
  11. #203
    Nov 2016
    Snohomish, WA
    Depends on what you want to use the boat for. The Sierra mounts I used were no good. Oversized by like a tenth of an inch. Solid mounts were out since I’m more of a pleasure boater. I ended up just buying new old stock OEM for $80 each pair.
  12. Thanks Glastron1987 thanked for this post
  13. #204
    Plainville, CT
    The OEM listed part numbers are 78687 (upper) and 78249(lower) for the Long/Jet, but 77326 (upper) and 77327 (lower) for the XL/XR4/XR6. Anyone know why/what the difference is? Also, from what pictures I see the OEMs look like metal around rubber, but the Sierra (although they may not fit) appear all rubber? Makes me think the OEM would be stiffer.
    Btw the boat this motor will be going will be used for (kids) tubing, skiing, barefooting and racing once in a while.
  14. #205
    Nov 2016
    Missouri
    My brother made my delrin mounts using a mill and he had to massage them to make them fit, it would of been way easier to make on a lathe though.
  15. Thanks Glastron1987 thanked for this post
  16. #206
    Sep 2017
    Ashland city tn
    I would go with OEM if u don't want solids , OEM is rubber with a metal "housing"
  17. Thanks Glastron1987 thanked for this post
  18. #207
    Nov 2016
    Snohomish, WA
    Mine was the XL, so the choice was made for me. But I remember scrolling through a lot of the “wrong” parts numbers for my application on eBay and wishing I could use them. The Sierra mounts looked to be solid Delrin. They were just too fat and my adapters wouldn’t mate proper without overtorquing. I thought about chucking them up, but after deliberating, decided the stock ones lasted this long, if they last that duration again, it’s worth the $$$.
  19. Thanks Glastron1987 thanked for this post
  20. #208
    Plainville, CT
    Since the plates that sandwich around the the upper mounts are the same for all of the engines, why would there be a different number for the mounts for the long/jet (i.e. 78687) as opposed to the XL/XR6 (i.e. 77326)? Are the mounts difference in some way? Also it seems some suppliers don't carry the 78687 anymore and/or list the 77326 for the long/jet also.
  21. #209
    Jun 2018
    Floating around
    Edit, Whoaa apologies all. This thread showed as one page when I first looked at it and I posted that redundant nonsense.
  22. #210
    Plainville, CT
    I just bought two OEM mounts for the top and plan to use solids for the bottom. Anyone else do this? How did it work out?
  1. 1994 Mercury 2.5 260 Rebuild
    By Rock Steady in forum Technical Discussion
    Last Post: 07-30-2022, 06:03 PM
  2. 1994 Mercury Pro Max rigging
    By Warrenroadie in forum Technical Discussion
    Last Post: 02-17-2017, 04:01 AM
  3. Mercury Tech: 1994 2.5 200HP Mercury EFI XR
    By FL_Sanger_Barefooter in forum Technical Discussion
    Last Post: 06-26-2016, 08:20 AM
  4. Mercury Tech: 1994 Mercury 175 2.5 oil conversion
    By Liberator225 in forum Technical Discussion
    Last Post: 04-23-2012, 07:10 AM
  5. Need Some info on 1994 Mercury 200 xri
    By cheapbeater in forum Technical Discussion
    Last Post: 04-16-2009, 10:20 AM
